CandlePowerForums
CPF Only
User Name
Password
Register
Advertising on CPF!
Reply
Thread Tools Display Modes
  #1
Old 03-15-2005, 04:02 PM
Zelandeth's Avatar
Zelandeth Zelandeth is offline
Default Interesting fluorescent nightlight @ Homebase
Actually thought initially that this might be an EL unit, but at £2.99 that would make it rather cheap for that. And the form factor was rather odd - but I know EL panels can be bent into a cylindrical shape. But it obviously wasn't incandescent, it was cheap, and I was bored. So I bought it.
Turned out when I plugged it in, the brief flicker followed by a cool white light gradually getting brighter for a minute or so, unmistakable. It was a fluorescent tube under that little frosted window.
This appears to be the smallest hot cathode fluorescent tube I've ever seen. Slightly under 2 inches in length. It does flicker a little, but not excessively so. Colour's much like that from a cheap fluorescent lantern. Very high colour temperature.
Driver circuitry's the difinition of simple. 2 capacitors, 4 resistors, one switch and the tube itself. Oh, and a fuse.
Power consumption. My power meter shows the following (after giving it an ample 15 minutes to warm up):
Power (real): 0W
Power (apparent): 8VA
Current: 30mA
PF: 0.1
So, lousy power factor, but it's actually using next to no power. It is obviously using something, but the meter I'm using only has a 1W resolution.
It's not hugely bright - but it's meant to be a nightlight! Is certainly bright enough to see your way around by. Certainly comparable to the "normal" 7W incandescent nightlights I've seen. And being fluorescent it's just that much cooler!
Has been running now for nearly five hours, and it's no more than slightly warm to the touch.
Also has a 1 year warranty.
Will add pics shortly - presently fighting with my server and out of date SSL certificates, can't upload images right now.
EDIT: Fixed the glaringly obvious typo. Somehow I managed to write unrecognisable rather than unmistakable. Oops!
EDIT 2: PICS! Got the server sorted out. Turned out to be a simple problem.
  #2
Old 03-15-2005, 09:56 PM
Brock's Avatar
Brock Brock is offline
Administratior
Default Re: Interesting fluorescent nightlight @ Homebase
Where did you get it? Any pic's?
  #3
Old 03-16-2005, 12:14 PM
Phaserburn's Avatar
Phaserburn Phaserburn is offline
*Flashaholic*
I count on you, Zelandeth, to find such gems and post them. Thanks!
  #4
Old 03-16-2005, 02:16 PM
Zelandeth's Avatar
It's a well known fact that I have a soft spot for fluorescents - especially inordinately small ones. This is certainly the smallest one I have so far.
Given the simplicity of the driver, we probably won't be seeing the best possible performance, lumen mainanence or lifetime from the tube - but this thing is seriously cheap. Also, everything runs cool - that to me is a major point to be considered when looking at something which is intended to be operating for expended periods without supervision. Case is still only slightly warm to the touch after around 35 hours continuous operation.
This one was bought in the Aberdeen Homebase store in the Bridge of Don industrial estate.
I'd offer to pick a few up for folks if they wanted - but being in a 220V 50Hz area, folks in the UK are the only ones likely to be interested. That said, the tubes themselves might still be of interest to someone. The producer of these has proved that it's easy to create a simple driver. Which I shall try to get a clearer photo of this evening if required.
  #5
Old 03-17-2005, 08:53 PM
eluminator eluminator is offline
I've got a 1.5 watt fluorescent night light, but the circuit is more complicated. It has an SCR among other things.
I like mine. I had a choice, so I chose the warm white. Mine has a photocell, but like all the photocell nightlights I've got, it's not worth much. The light stays on all day unless the blinds are open and the sun is shining brightly.
I'm worried that the bulb won't last long so I plugged it into a timer. Unfortunately the timer cost a lot more than the light. I'm thinking I could control several nightlights cheaply with some kind of an X-10 gadget.
http://www.nolico.com/saveenergy/low...ight_light.htm
  #6
Old 04-03-2005, 07:49 PM
phyhsuts phyhsuts is offline
The extra circuitry is for the automatic control to turn the light on and off depending on the light level. Capacitive ballast nightlights are made by many many manufacturers in China. Here in Singapore we get them for as low as US$1.40. No room light level sensing though [img]/ubbthreads/images/graemlins/grin.gif[/img]
  #7
Old 04-05-2005, 06:05 PM
Zelandeth's Avatar
Small update: It's been reported to me by another CPF user that similar lights are also available from Maplin Electronics. And it would appear so.
Maplin Electronics
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
