CandlePowerForums
Go Back   CandlePowerForums > Flashlights > Flashlight Electronics - Batteries Included
CPF Only
User Name
Password
Register
Led-Replacement
Closed Thread
Thread Tools Display Modes
  #1
Old 03-25-2005, 05:13 PM
SilverFox's Avatar
SilverFox SilverFox is offline
Silver Moderator
Default NiMh Battery Shoot Out
Last Revision Date, 3/11/2008
I will add graphs as I finish the testing. If you have some NiMh cells that you would like to see the test results of, contact me for my shipping address so I can borrow a couple of cells for testing.
The graphs will pretty much speak for themselves, so let's get started...
Brock asked me to put up a comparison at a 1.0 amp discharge rate. I thought of doing this type of graph for all the discharge rates, but decided to do individual graphs to show the performance range of the different cells. This will serve as a general comparison between cells. For a more detailed look, check the individual graphs.
This graph was getting extremely cluttered, so I have replaced it with a table. The cells are sorted by Watt Hours.
JT loaned me a couple of Quest Platinum AA cells that are rated at 2300 mAh. Thanks JT.
Sigbjoern loaned me some Kodak AA 1700 mAh cells and here is how they perform.
A big thanks to Sigbjoern, he also loaned me some of the CBP AA 1650 mAh cells. These are high current cells. Here is what they look like.
To get the maximum performance from the CBA 1650 cells, you need to run them hot. Here is the 15.0 amp test showing the performance difference between hot cells and room temperature cells. CAUTION: Running lights on these hot cells may result in insta-flashing the lamp.
Here are the results on the Energizer AA 2300 mAh cells.
Here is the graph of the Energizer AA 2300 mAh cells that Brody sent me. I am not sure why there is such a difference between his cells and mine, but his are more in line with what I expected from these cells.
I am not sure who makes these cells, but they have a green sleeve and are rated 1400 mAh. They were part of a promotion when I got my charger and I believe they are very inexpensive. I took the results of an average cell, but be advised that each cell (of the 4 I have) tested differently and the range from highest to lowest was about 30%. I have learned to lower my expectations of free cells...
Here is the data from some Radio Shack 1500 mAh cells I have been using.
Here are the results for the Titanium 2400 tests. These are one of my favorite batteries. They hold voltage very well and are capable of some misuse as well. I have been using these cells in my Battery Charger Shoot Out and have been very impressed with them. I have also been impressed that they are very consistent from cell to cell. They may not be the best in a 10 amp application, but they do very well for a consumer grade cell. I got my cells from www.amondotech.com and I will be getting more of these cells.
Brody pointed out in a post below that other people testing batteries have found the Titanium 2400 cells to be very good as well. Wayne, if you happen to read this, thanks for an excellent AA cell and I hope you don't feel the need to change it.
Here are the graphs of the Titanium 2400
I am also very impressed with the Titanium 2000 cells. They have the same ability to keep a higher voltage during discharge, but just have a bit less capacity. It almost seems to me that the cells are put through a sorting process and the high capacity cells are the 2400's and if they don't meet the higher capacity, they go into the 2000 bin. These cells are also very consistent from cell to cell and perform very well.
Sanyo has always been a strong performer. Here is the data from the Sanyo 2300 mAh cells. They are strong performers. Thanks Brody for providing these cells for testing.
Here is the results from the Duracell 2300 cells. Thanks Brody again.
Brody also sent me some Energizer 2500's. Thanks Brody. These are interesting in that the harder you hit them, the better they perform. Very impressive at 5.0 amps.
4/13/05 Brody also sent me some Sony AA 2300 cells. Here is how they check out.
Brody also sent me some La Crosse AA 2000 cells. I also have these cells as do most people that purchased the La Crosse charger. There is some inconsistency between cells, but it is not too bad. Considering they were free, they are not too bad. Here is the graph.
Brody also sent me some Sanyo HR Industrial AA 2500 cells. These are the ones in dark green shrink wrap. What can I say - these are excellent cells. Sanyo is known for their quality and it shows. Here is the data.
Brody also sent me some Sunpack AA 2300 mAh cells to check out. 2300 mAh is a GROSS overstatement. I am not sure what Sunpack is trying to do here, but their cells don't even come close to 2300 mAh. Here are the graphs.
Brody also lent me some JetCell AA 2400's. These came from www.RipVan100.com the same people that have the excellent charger the Lightning Pack 4000N. The only issue I have with this charger is that it charges pairs of cells rather than individual cells. These cells performed very well. Here are the graphs.
Litho123 loaned me some Ray O Vac AA 1800's. Thanks Greg. They actually look pretty decent. Here is the data.
Litho123 also loaned me some Ray O Vac IC3 2000's. These cells are designed to work with the Ray O Vac IC3 15 minute charger, but can be charged by other chargers as well. My Energizer 15 minute charger did not like them. At the end of charge, the IC3 cells interrupt the circuit and the Energizer 15 minute charger would start the charge cycle again. Several rounds of this and you end up with a IC3 cell getting hot and an Energizer 15 minute charger with a blinking red light indicating something is wrong. At any rate, the cells did well. Here is the data.
Litho 123 also sent me some Energizer AA 2100's. These are the cells that come with the Energizer 15 minute charger.
Here are the GP AA 1800's that Litho 123 sent me. I am not sure how these cells fit into use categories, but I have noticed that GP has some high performance (high current) cells that work best "hot off the charger." I tested these cells using my normal cool down because I believe this is representative of how we would use these cells in our lights. They do hold voltage very well at 5.0 amps.
Sigbjoern is having me check out some cells for him. One of these is the AccuPower AA 2600's. They did very well.
Sigbjoern's AccuPower C 6000 mAh cells.
Sigbjoern's AccuPower D 11500 mAh cells.
Sigbjoern's 4/5A cells from MaxAmps rated at 1800 mAh. These are geared to high current draw applications and do quite well.
Sigbjoern also has me going on some 2/3 A cells. These are GP 1100 mAh cells and I am very impressed with their performance. The are sensitive to heat. You will notice the similarities in the 15 and 20 amp curves. The 20 amp test was done with cells hot off the charger. When the cells cool down, they fall on their face at 20 amps. At any rate, these are some real performers.
Here is the data on the MaxAmps 2/3 A 1150 cells. Thanks Sigbjoern.
Here is the data on the KAN 2/3 A 1050 cells. Once again thanks Sigbjoern.
I was having fun playing with (testing) these cells. The test at 5.0 amps was done with "warm" cells (about 90 F) to see what effect a little temperature has. As you can see, it helps a lot.
You have to love a cell that gives it rated capacity at 3C. Sigbjoern had me look at some KAN 2/3 AA 650 mAh cells. These are great performers. Here is the graph.
Here is some data from Supreme Power AA 1800 cells. Thanks to whoever sent me these cells. I forgot who it was… It was Sigbjoern - Thanks.
Lasercrazy loaned me some Powerex AA 2300 mAh cells to check out. These cells check out for perhaps 1800 mAh cells, but are nowhere close to 2300 mAh cells. I wonder if they were mislabeled.
Lasercrazy also loaned me some Ansmann AA 2300 mAh cells. They look pretty good.
Rick88 sent me some X1 cells to check out. I am not sure who makes these cell, but they did pretty well. Thanks, and sorry it took so long to get them back to you.
I finally got some Titanium 2600 mAh cells. They are looking pretty good…
If I asked you to run down to the local store and pick up some Vapextech NiMh batteries, would you look at me and wonder what I was talking about? If you live “across the pond” you may be familiar with this brand, but I am not sure it is available in the US. Ian Lewis of www.component-shop.co.uk sent me some of these cells to test. I am very impressed with how they perform. They are advertised to be good to 7.5 amps. They are performing well at 5 amps, but fall on their face at 10 amps, so I can believe they could hold up at 7.5 amps. At any rate, at 5 amps they are doing quite well. If you happen to see these cells, don’t be afraid to purchase them. They held up quite well.
Here is the test data.
AmondoTech is offering some Titanium AAA 1000 mAh cells. These did pretty well for themselves. There are not many AAA cells that can hold up to a 3.0 amp discharge rate and maintain descent voltage. Here are the graphs.
William at www.MahaEnergy.com sent me some Powerex AA 2500 mAh cells to check out. Thank you William. I had tested some Powerex cells earlier, and they did not perform very well. I decided to really put these cells through their paces to see how well they perform.
In addition to the test runs, I used these cells in my PT Yukon Extreme and my Mag85 for several cycles. I have come to the conclusion that these are very good cells. They perform very well at high loads as well as at lower loads, and they seem to be holding up over the 40+ cycles I have put them through.
I don’t know what happened to the earlier cells that I tested, but these 2500’s are very good performers.
I ran a test at a 7.5 amp draw because I was told that these cells were designed to hold over 1.0 volts at 3C. As you can see, they hold up to their specifications.
Here are the graphs. At 10 amps they kind of fall on their face, but they did not heat up and that’s a lot better than most consumer cells do.
UnderDog sent me some Sanyo Eneloop cells to check, along with the Sanyo NC-MDR02 charger. This is a 2 cell charger and I have not had a chance to fully check it out, but it is on the list.
Thanks Mark.
The advantage of the Eneloop cells is that they have a reduced self discharge rate. Sanyo advertises that they have 85% of their original capacity after 1 year of room temperature storage. Keep in mind that the self discharge rate goes up at elevated temperatures.
Here is the graph.
Did you notice that at 10 amps the voltage is still holding above 1.0 volts?
The self discharge test revealed that in 31 days there is 93% of the original capacity remaining. I do not know if this self discharge rate remains linear, but in discussing the new battery chemistry with Wayne at AmondoTech, he mentioned that he is under the impression that the self discharge rate slows down the longer the cell is stored. It does not completely stop, but it is slowed down to almost nothing.
If we assume that what I measured in 31 days is linear (worst case), that means that at the end of a year you would end up with about 44% of the original capacity remaining.
Considering that with a normal NiMh cell you would end up with 0% capacity left, this is still quite an accomplishment.
I tested a Sanyo 2500 mAh cell that has been stored at room temperature for 30 days. It ended up with about 82% of its initial capacity. It looks like the Eneloop cells do perform better...
Andy (MorePower) sent me some RayOVac Hybrid cells to check out. These are also low self discharge rate cells, and they did a very good job.
Here is the graph.
I have them at retaining around 86% of their initial capacity after 30 days. Not quite as good as the Eneloop cells, but much better than normal NiMh cells. Very impressive.
Thanks Andy.
LEDcandle sent me some Supreme Power 2300 mAh cells to check out. These are flat top cells similar to the CBP 1650 cells. These did quite well, but I am sure their performance could be improved if they were tested hot.
Here is the graph of the test results.
Shaocaholica sent me some AccuPower 2900 mAh cells to check out. Thanks.
These cells are strong performers and do have more capacity. They fell on their face at 10 amps and the test only lasted about a half a minute. I did not include the 10 amp test data.
Here is the graph.
Sanyo also has a high capacity cell listed at 2700 mAh with a minimum of 2500 mAh. These cells are also strong performers and did survive a 10 amp test, although the voltage dropped a lot during that test. The BC-900 (1000 mA charge 500 mA discharge) in test mode is showing around 2800 mAh when you discharge immediately after charging.
I had two batches of 4 cells to check out. Thanks Shaocaholica and Action. All 8 cells seemed to be reasonably well matched.
Here is the graph.
A slight digression, if I may... I know this is about various NiMh cells and how they perform, however, Ifoxbox sent me some 4/5A Sanyo KR-1100AEL NiCd cells to check out. You have to love NiCd cells for their ability to hold up under load. These are very strong cells. They finally started to drop off during the tests at 20 amps. That's a little over 18C. Impressive.
Thanks Jake. Now if they had 2500 mAh AA sized cells with this kind of performance...
Here is the graph.
Macdude22 sent me some Digital Concepts AA 2500 mAh cells to check out. These cells also have Rechargeable written on them. The seem OK for lower current draw applications, but do not handle high currents very well at all.
Here is the graph.
Well, what do you think of the new Titanium Power Max high current 1800 mAh cells...
Very impressive. Cold, they almost perform better than the CBP1650 cells hot. I have not looked at them "hot off the charger," but in "normal" use, they hold up very well.
You will notice that they fell on their face AT 20 AMPS, but were doing quite well at 15 amps. They are only rated at 18 amps, so I will cut them some slack. Also, note that they are at their rated capacity at a 1 amp draw.
I believe there are going to be some USL packs made from these cells because of their strong performance.
Here is the graph.
Macdude22 also sent me some Tenergy cells to test. I received 2 of the 2600 mAh and 2 of the 2300 mAh cells. Everyone knows that Tenergy is very optimistic with their labeling, so it should come as no surprise that they came in at less than their rated capacity.
The problem I had with these cells is that each cell tested differently. They are not consistent from cell to cell. I have done a couple of deep discharges followed by forming charges without improvement. I finally ran a Break In cycle on the Maha C9000.
Here are the results from the Break In:
Cell #1 labeled 2600 mAh, actual capacity is 2319 mAh
Cell #2 labeled 2600 mAh, actual capacity is 1960 mAh
Cell #3 labeled 2300 mAh, actual capacity is 1909 mAh
Cell #4 labeled 2300 mAh, actual capacity is 2035 mAh
I will not be posting graphs for these cell. The results are all over the place and not consistent from cell to cell. I have no idea of what is going on with these cells. Perhaps Macdude22 and give us some history on them.
Others have also observed the inflated capacity ratings, but have had good consistency from cell to cell. I will reserve any further comment until I have had a chance to check out some other Tenergy cells.
GCBStokes sent me some Titanium 2700 mAh cells to check out. The Titanium cells have been very strong performers. They are labeled a little optimistically, but then have been proven to have excellent cycle life.
These are not the cells to use for loads over 5 amps, but at lower loads they do very well.
Here is the data.
I had some Duracell 2400 mAh cells that I ran some test on.
Here is the data.
Codeman sent me some Duracell 2650 mAh cells to check out.
Here is the data.
Thanks Ray.
Here is some data from the Eneloop AAA 800 mAh cells. They seem to work well at lower current draws, but fall on their face at about 4 amps. That is impressive from an AAA cell.
MorePower also sent me some RayOVac Hybrid AAA 800 mAh cells to check out. These are also low self discharge rate cells. Like the Eneloop cells, they fell on their face at 4 amps, but that’s pretty good from an AAA cell.
Here is the data.
Thanks again Andy.
Cannesahs sent me some GP ReCyko AA cells to check out. The capacity was not labeled, so I guessed at 2050 mAh. EDIT: In fine print on the cell it states that these are 2100 mAh cells with a minimum of 2050 mAh. ENDEDIT These seem to be very strong cells. They fell under 1.0 volts under a 10 amp load, but still gave a decent performance.
It will be interesting to see how well they keep their charge over time. These are supposed to be low self discharge rate cells.
Here is the graph.
Thanks Jyrki. Self discharge rate testing is in progress...
Tom
  #2
Old 03-25-2005, 05:35 PM
evan9162 evan9162 is offline
Default Re: NiMh Battery Shoot Out
How are you charging?
  #3
Old 03-25-2005, 06:56 PM
Bullzeyebill Bullzeyebill is offline
Not so hot, the Quest cells. Have these been cycled a few times to bring capacity up?
Bill
  #4
Old 03-26-2005, 07:58 AM
SilverFox's Avatar
Silver Moderator
Hello Evan,
Charging is done on a Vanson BC-1HU. Green light + 30 minutes.
Tom
  #5
Old 03-26-2005, 08:01 AM
SilverFox's Avatar
Silver Moderator
Hello Bill,
Cycling is done in the "Refresh" mode on the La Crosse BC-900 charger at 500 mA charge rate and 250 mA discharge rate.
Tom
  #6
Old 03-26-2005, 11:51 AM
Hans Hans is offline
[ QUOTE ]
SilverFox said:
This is just getting started. I will add graphs as I finish the testing. If you have some NiMh cells that you would like to see the test results of, contact me for my shipping address so I can borrow a couple of cells for testing.
[/ QUOTE ]
This is going to be very interesting. I'd quite like to see some results for the Sanyo 2300 mAh cells. My feeling is they're the best cells I ever used.
However, shipping them to the US won't really make much sense ... [img]/ubbthreads/images/graemlins/icon23.gif[/img]
Hans
  #7
Old 03-26-2005, 12:36 PM
Tom, would you like a couple of CBP 1650's to test?
Bill
  #8
Old 03-26-2005, 12:53 PM
SilverFox's Avatar
Silver Moderator
Hello Bill,
Thanks, but Sigbjoern already loaned me 18 to check out. I will post the results shortly.
I just added graphs of the Kodak AA 1700 mAh cells.
Tom
  #9
Old 03-26-2005, 02:09 PM
Ginseng Ginseng is offline
Tom,
Please post your Titanium 2400 results as well. Those appear to be some very nice cells.
Wilkey
  #10
Old 03-26-2005, 08:07 PM
litho123 litho123 is offline
Hi Tom -
Please PM me your addy along with qty of batts you need for testing.
I can send you the Ray-O-Vac I-C3 2000 nimh and also the GP 1800 nimh for testing.
Thanks for doing this!
Greg
  #11
Old 03-26-2005, 10:10 PM
SilverFox's Avatar
Silver Moderator
Hello Greg,
Thanks, PM sent.
Tom
  #12
Old 03-26-2005, 10:29 PM
Whooho! Look at those CBP 1650's. Looking really good out to 10amps. Will do everything, most everything, that CPF'er require in an AA, and competes with the 4/5A cells.
Bill
  #13
Old 03-27-2005, 03:24 AM
MrAl's Avatar
MrAl MrAl is offline
Hi there,
Energizers look pretty good...im wondering how many cells
were tested...
Of the Duracells i've tested, i found them to be not
as good as that. Only one came near it's supposed rating,
and that one cell (out of four tested) was slightly
higher than it's rating.
Would be nice to see some more Duracells tested too.
Take care,
Al
  #14
Old 03-27-2005, 08:35 AM
SilverFox's Avatar
Silver Moderator
Hello Al,
When someone offers to loan me cells for testing, I request at least 2. I do several tests on them after cycling them for a minimum of 4 cycles.
My own cells are usually bought in packs of 4.
The Energizer data is based on 8 cells that I was pleased to find that out of the pack they are very closely matched.
I am amazed at how close most brands of AA cells are (cell to cell) once they are cycled a few times and properly charged. I have found a few that are under performing by around 3-5%, but for the most part they are very close.
C and D cells are another story...
Tom
  #15
Old 03-27-2005, 11:59 AM
DaGeek DaGeek is offline
Thanks very useful!!
  #16
Old 03-27-2005, 05:08 PM
MrAl's Avatar
Hi Tom (SilverFox),
Oh ok, that's great. I was hoping to see some average
results rather than just one or two cells tested.
I hope you can get to check Duracells at some point,
as i have found my group (of 4) wasnt exactly what
i expected from a major company like that.
From the graphs i see one of the other manufacturers
batteries didnt perform too well either, but i like
the looks of the Energizers.
Im finding that many of my applications require either
low current or low useage -- either of which isnt a good
app for using NiMH's so i'll probably be turning more
and more to Li-ion's (higher voltage per cell too).
The problem with the low current device i find is that
the self discharge is the main factor in determining
when the cell(s) will need charging again, and ditto
for low useage. I still like using the cells somewhat
however, because, after all, they are rechargable so
they can be used many times over.
Take care,
Al
  #17
Old 03-27-2005, 10:32 PM
paulr paulr is offline
I'd be interested in seeing tests of the Batteryspace (Powerizer) 2300 mah cells since those are very attractively priced:
http://batteryspace.com/index.asp?Pa...D=245&HS=1
Also, where can I buy some CBP's, and should I bother, for a Mag85? If I can get reasonable results with the Powerizers, I might use those instead, since they're sold in bunches of 24.
  #18
Old 03-29-2005, 12:29 AM
PeLu PeLu is offline
[ QUOTE ]
Hans said: like to see some results for the Sanyo 2300 mAh cells. My feeling is they're the best cells I ever used.
[/ QUOTE ]
Yes, I agree, they have a higher capacity (at 0.8A) than the Varta IC-3 2.3Ah cells.
Usually they are a little above 2.2Ah when charged with the Uniross.
Waht about the 2.5Ah Sanyo?
  #19
Old 04-01-2005, 05:21 PM
SilverFox's Avatar
Silver Moderator
Brody sent me some cells to check out. Thanks Brody.
He just happened to send me some Energizer 2300's. I have already posted results on these cells and was going to pass over them, however I decided to run a few tests just to see how they compare.
They are far better than the cells that I have. I am not sure what is going on with these cells, but I will be posting another Energizer graph of the cells Brody sent me.
My cells were purchased at Wal Mart in an 8 pack and I have been using them for some time in my GPS. It uses 4 at a time and shuts off when the cells are down to about 1.0 volts. My cells are very evenly matched.
Brody's cells (he sent me 2 of them to check out) are also evenly match, but are performing much better. My cells fall flat on their face at a 3.0 amp discharge. Brody's cells are taxed at 3.0 amps, but they try to hold about 1 volt.
This is quite shocking, I had expected Energizer's to be more consistent. I will have to get in touch with Brody and see when and where he got his cells from.
I guess the old saying still holds true:
Your mileage may vary...
Tom
  #20
Old 04-01-2005, 05:52 PM
yuandrew's Avatar
yuandrew yuandrew is offline
Have you tried regular Rayovac Ni-Mh's ?
I have some or you can get them at Wal-Mart
  #21
Old 04-01-2005, 10:43 PM
It may be nuts but I'm about to order a pile of Sanyo HR-3U 2500 mah cells from batterystation ($2.50 ea, almost double what the Powerizer cells cost). Tony, PM me your address and I'll send you some of them when they arrive.
  #22
Old 04-01-2005, 11:33 PM
Brody Brody is offline
I got my Energizer 2300's at Best Buy about a year ago. They mostly have just been powering my MP3 CD player most of the time. I would just recharge them once a week or so on my Lightning Pack 4000 charger. I normally listen to my CD player about 2-4 hours a day. I know that the player can go about 30 hours or so if I let it play continuously until it stops.
I was almost not going to send the Energizer 2300's since you had already told me that you had some, but I decided to send 2 anyway. I felt pretty much the same way with the La Crosse cells that I got with my charger, since I know that your set is probably about the same age as mine.
I look forward to seeing how the other cells that i sent perform. I know others are looking forward to seeing results from Duracell 2300's, Energizer 2500's, Sanyo 2300's, Sanyo 2500's like I sent you. I also like the Jetcell 2400's I sent. I sent some Sunpak 2300's as well, but for me, the Sunpak's have always performed very poorly.
(Oh, the Sanyo 2500's I sent were the industrial grade variety. That is why they are just in plain green labels. However, the industrial cells are supposed to be more resistant to damage, and are supposed to be able to recharge for more cycles than the consumer grade cells, so it will be interesting to see how they do)
  #23
Old 04-02-2005, 12:26 AM
[ QUOTE ]
[/ QUOTE ]
I sent SilverFox:
the regular Ray-O-Vac 1800 nimh (from Wally world)
the GP 1800 nimh
to test.
I know he'll post the results just as soon as he can.
I'd like to know too.
  #24
Old 04-02-2005, 03:34 AM
koala's Avatar
koala koala is offline
I stand corrected with those Energizer 2300mAh cells results. Most of us know they are actually rebadged Sanyo HR2300 but what 'bin' is unknown. Most of my Energizer 2100mAh cells can delivered at least 2.0Ah at 0.5C(1.0Ah) discharge.
From the posts above, there seems to be different opinion on cells capacity. Could it be difference from batch to batch? Could it be the 'quality' of metals material used in the cells that affects the performance?
Another one, has anyone tried out the green+orange sleeve GP AA/AAA cells? I've seen alot of RC people racing high discharge with GP 3300 cells.
-vince.
  #25
Old 04-02-2005, 06:51 AM
SilverFox's Avatar
Silver Moderator
Hello Paul,
PM sent.
Tom
  #26
Old 04-02-2005, 07:00 AM
SilverFox's Avatar
Silver Moderator
Hello Brody,
I guess we must have cells from different batches. I knew there must be some differences between batches, but am shocked at how big the difference is. It seems like the overall capacity is about the same, but my cells will not hold voltage as well as yours.
By the way, my La Crosse charger capacity results are very similar to yours. [img]/ubbthreads/images/graemlins/smile.gif[/img] The actual test results show a bit less capacity because of the way I am testing. The La Crosse charger will start the discharge test immediately after charging the cell. I let the cell cool down for 30-60 minutes before testing.
Tom
  #27
Old 04-02-2005, 07:20 AM
SilverFox's Avatar
Silver Moderator
Hello Vince,
I believe Greg sent me some Energizer 2100's as well as some GP 1800's to test.
I am not sure what to make of the differences... Let me get the graph up so we can all see how much of a difference there is.
The casual user may not notice a difference at all, but in a multi cell light that pushes the battery a bit, there could be a vast difference in performance.
This makes me appreciate chargers like the La Crosse (and the ICE [img]/ubbthreads/images/graemlins/grin.gif[/img] ) that have a test function allowing you to check your cells out.
Tom
  #28
Old 04-03-2005, 04:41 PM
SilverFox's Avatar
Silver Moderator
OK, I have the comparison of the two batches of Energizer 2300's up.
The overall capacity is about the same at the lower current rates, but Brody's cells hold voltage much better than mine.
Tom
  #29
Old 04-03-2005, 07:11 PM
PlayboyJoeShmoe's Avatar
PlayboyJoeShmoe PlayboyJoeShmoe is offline
*Flashaholic*
Somebody get this man some Energizer/Sanyo 2100s!!!
[img]/ubbthreads/images/graemlins/popcorn.gif[/img] [img]/ubbthreads/images/graemlins/popcorn.gif[/img] [img]/ubbthreads/images/graemlins/popcorn.gif[/img] [img]/ubbthreads/images/graemlins/popcorn.gif[/img] [img]/ubbthreads/images/graemlins/popcorn.gif[/img]
  #30
Old 04-03-2005, 09:25 PM
[ QUOTE ]
[/ QUOTE ]
Energizer 2100's have already been sent to SilverFox for testing...just awaiting posting of results!
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
