CandlePowerForums
CPF Only
User Name
Password
Register
HDS Systems
Reply
Thread Tools Display Modes
  #1
Old 06-14-2005, 03:29 PM
jayflash jayflash is offline
Default GE Biax CFL Failures
The GE spiral CFLs have been holding up but their Biax lamps are burning up the circuit boards. I'm responsible for specifying and replacing thousands of lamps in several buildings and will be returning a bunch of bad Biax lamps to GE. 12kHr of lamp life?! Try a few hours on some.
What is your CFL experience?
  #2
Old 06-14-2005, 03:42 PM
Zelandeth's Avatar
Zelandeth Zelandeth is offline
Default Re: GE Biax CFL Failures
Hmm,not got much experience with them, but I've got a couple of them running here, one 24/7 in a dark hallway. Presently, it's at *grabs calculator* 8795 hours and still going strong.
  #3
Old 06-14-2005, 08:27 PM
brickbat brickbat is offline
If you buy thousands of lamps, and are seeing lots of infant failures, I'd take it up with GE - sounds like a problem they'd like to know about.
Might be stating the obvious here, but not knowing your background I'll go ahead. The operating temperature of the board has a huge effect on its life. If a CLF is one of the bigger sizes, such as the 28 or 29W and being operated base up, or in an enclosed fixture the life can be pretty disappointing.
My CFL experience has been great, even with cheapie Chinese no-name lamps, but the only lamps I burn base up are 14 Watts and smaller sizes, and run pretty cool.
  #4
Old 06-14-2005, 11:26 PM
mattheww50's Avatar
mattheww50 mattheww50 is offline
I cannot comment on the GE's biax, the Feits(LOA) hae been a disappointment. I won't buy them. I have had good experience with the Sylvania's, the GE's with magnetic ballasts in the base, and the Panasonics.
I was an early adopter of the Philips CFL, and none of them got anywhere near the specified life (most died inside of 6 months). I wrote to Philips with the manufacturing dates. They didn't argue, they just sent me a case as warranty replacements. I guess they knew they had a problem..
The replacements lasted long enough that I don't know if they ran for 10,000 hours, but it was long enough that wasn't going to argue about it.
  #5
Old 06-15-2005, 05:23 PM
The only GE CFL specified to use base down is the spiral, 42 watt, model. I've got a ton of the 26watt spirals base up in enclosed cans with nary a failure. I've been experimenting with the biax due to the (advertised) better lamp life. Some of the biax will light at low ambient temperatures and, therefore, lend themselves to outdoor use during Wisconsin winters.
The problem is circuit board failure and I have discussed this with a rep. I'm waiting to see if they come through for me.
  #6
Old 06-15-2005, 07:14 PM
VidPro VidPro is offline
i was doing great with "lights of america" things (undoubtedly made in china :-) then i got a slew of bad 42W types. sent 4 back, and rapidly recieved from LOA 4 NEW ones, no charge for shipping even.
the 4 lasted a few days, much less time that the original 4. just when i thought i was getting good service [img]/ubbthreads/images/graemlins/frown.gif[/img]
  #7
Old 06-18-2005, 10:09 PM
greenLED's Avatar
greenLED greenLED is offline
I forget what brand we have at home (got'em at Costco), but most of them didn't last 1 year of "normal" household use.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
