Re: Source for glow in the dark O rings?
Would you paint o-rings? I might have this wrong but I thought flashlite was planning on using o-rings externally as a locator rather than a seal. Either way, painting rubber isn't the best way IMO.
GreenLed has the idea a lot of people are going with these days which is a clear epoxy (no UV filters) mixed with some colored glow powder to make a workable paste, then applied to the light anywhere (in reach of the lights' photons is an ideal spot).
If you aren't placing the epoxy near the business end of the light, a ring around the bezel is also common. When applying around the bezel or light (round surfaces in general), the epoxy tends to hold a smooth finish and flows evenly around the light (assuming you're doing a ring like an o-ring) if you keep turning the light for a minute or two til it cures slightly.
The MOST IMPORTANT thing to remember if you are applying poxy'n'powder is to make sure there is a white background to assist the glow factor. I got a french white nail polish that I have used to good effect. I recommend a white surface, definitely not liquid paper/whiteout etc!
I hope I made sense - I chopped and changed my answer a bit... [img]/ubbthreads/images/graemlins/smile.gif[/img]
Of course, if you can have Danny's paint shipped to you, that would be an option too. [img]/ubbthreads/images/graemlins/grin.gif[/img]
