CandlePowerForums
CPF Only
User Name
Password
Register
BugOutGearUSA
Reply
Thread Tools Display Modes
  #1
Old 09-01-2005, 08:29 PM
Bravo25 Bravo25 is offline
Default White to UV filter
I was just wondering if there is any such filter that changes white light spectrums to UV?
__________________
"LIFE………….is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - WOW - What A Ride!" #3475
  #2
Old 09-02-2005, 02:25 AM
Grox's Avatar
Grox Grox is offline
Default Re: White to UV filter
From what I gather (and I'm no expert)
- Filters only subtract light from the light coming out of the light assembly. They can not change frequencies or produce frequencies that were not originally present.
- Incans produce most of their light in the infrared range, so a filter which passed UV light only would be wastefully inefficient.
- White LEDs produce most of their light in the visible specture with a little UV. There is not enough UV to warrant filtering since to get enough UV to be useful you would have to have a very powerful LED output indeed.
I hope that helps.
edit: Rereading your question, I'm sure that there are filters that pass only UV light (eg. daylight). I guess they would use prisms to separate different wavelengths. But flashlight-wise your best bet is to get a UV LED source.
  #3
Old 09-02-2005, 04:25 AM
xpitxbullx's Avatar
xpitxbullx xpitxbullx is offline
I've made UV filters for the Mag85 that works pretty good. UV filters don't work with white LEDs and works best with HID.
http://candlepowerforums.com/vb/showthread.php?t=75028
__________________
I have too many flashlights (minus one)!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
