CandlePowerForums
Go Back   CandlePowerForums > Administrative > Practice Posting
CPF Only
User Name
Password
Register
BugOutGearUSA
Reply
Thread Tools Display Modes
  #1
Old 09-02-2005, 10:18 AM
UnknownVT UnknownVT is offline
Exclamation test thread name change *Change #2*
will return to edit thread name to add *Changed*
Edit - added *Changed* to heading/subject
Edit #2 - title change obviously worked here - but did NOT seem to work on an older test post/thread - Test - WYSIWYG
I had added *Test title Change* to the title - it shows it when the post/thread is opened - but does not show it on the actual thread list - unlike here.
Edit - changed title again (#2) to test for ability still to change titles
Sun Sept/04/2005 12:10PM EDT - this seems to have FAILED
  #2
Old 09-02-2005, 10:23 AM
chrisse242's Avatar
chrisse242 chrisse242 is offline
Default Re: test thread name change *Changed*
how did you do it?
  #3
Old 09-02-2005, 10:32 AM
chrisse242 wrote: "how did you do it?"
Please take a look at edit #2 in my opening post above -
I could not edit the title line on an older post/thread
I think that the title change will only work with a new'ish post -
Sasha had set an edit time limit to 100,000 minutes which is just under 10 weeks.
BUT my "unsuccessful" title change post is only 3 days old.
So a "guess" may be the title change is only possible with threads posted after Sasha made the permission change?
Last edited by UnknownVT; 09-02-2005 at 10:44 AM. Reason: corrected to 100,000 minute limit
  #4
Old 09-02-2005, 10:34 AM
chrisse242's Avatar
Seems like you're right. Doesn't work with my older threads as well...
Chrisse
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
