Infrared light and auto windshields.
Ok... now i recall hearing about it but i'm not sure what it is.
The reason why i'm asking is because i recently attained a cruise card for the tolls in my state. The instructions say "place 2 inches below top of windshield behind rear view mirror." But then it goes on to talk about "higher end cars" where some of the windshields like the BMW 745 will block out "infrared light". The instructions them go on to say which spots on that particular model will block out infrared light.
I dont drive a bmw. But i do drive an Acura. 2 inches from the top of the windshield is sort of this blue strip that helps keep the car cool. It's pretty much the same as the Honda's have at the top of the windshield.
Will that block out infrared light? The instructions didn't say anything about that. I dont want to start racking up tickets without even knowing it when i'm cruising through the CC lane at the tolls.
thanks in advance. Sorry if this is in the wrong forum, but i tried actually posting this in a car forum and nobody knew what infrared light was. I figured here... it'd be a no brainer for some of you guys.
Is infrared light like the signal that the TV remotes give out?
I'm guessing that since this cruise card has a small 3 volt battey in it... at the cruise card lane, there's a beam of infrared light constantly shinning down through the lane, then when the card picks it up, it will shoot back the cruise card #. Is that why if infrared light is blocked it wont work?
thanks again.
Reason: Dano:Clarify subject matter
