CandlePowerForums
Go Back   CandlePowerForums > Administrative > Practice Posting
CPF Only
User Name
Password
Register
PEAK LED Solutions
Reply
Thread Tools Display Modes
  #1
Old 10-16-2005, 02:31 AM
L.E.D.'s Avatar
L.E.D. L.E.D. is offline
Default practice
case material : high grade barstock aluminum
bulb type : 'hollow point' 20 watt LED
beam equipment: metal reflector plus new "reflective convex backfire" system (LED is still mounted at back of reflector)
beam manipulation: spot to flood
beam description: circular tight spot with sidespill and no artifacts(narrowest); circular 120 degree flood(maximum flood)
batteries: 8 D cells
length: 15 inches
width: 4.5 inches
brightness: (narrow)8,500,000mcd at 12 inches (hotspot)
regulation: "dead flat"
thermal management: special design heatsink
brightness control: yes, non-pwm
switch type: magnetic reed (slide)
accessories: swappable LED modules for desired color(s) (no soldering/desoldering required)
submersible: 1000ft
price: lol
  #2
Old 10-17-2005, 11:42 AM
matrixshaman's Avatar
matrixshaman matrixshaman is offline
Default Re: practice
LOL - test post
__________________
There is no important work, there are only a series of moments to demonstrate your mastery and impeccability. Almine
  #3
Old 10-17-2005, 09:27 PM
nemul's Avatar
nemul nemul is offline
i wanna see a 20 watt LED...
  #4
Old 10-21-2005, 02:12 PM
underdust underdust is offline
Just testing
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
