CandlePowerForums
CPF Only
User Name
Password
Register
FoxFury Sunbolt 6!
Reply
Thread Tools Display Modes
  #1
Old 11-09-2005, 02:47 PM
rycen's Avatar
rycen rycen is offline
Default Anyone using HIR bulbs in your car?
I know that HID wont work with stock reflectors but what about HIR?
  #2
Old 11-23-2005, 03:15 PM
rycen's Avatar
Default Re: Anyone using HIR bulbs in your car?
bump
  #3
Old 11-23-2005, 03:21 PM
greenLED's Avatar
greenLED greenLED is offline
what's HIR?
  #4
Old 11-23-2005, 03:23 PM
Led_Blind Led_Blind is offline
I think HIR is a halogen globe that has a special coating that reflects infrared back onto the filament. The theory is that the added heat on the fillament improved efficencies.
use HID . .they are still brighter.
EDIT: To answer the origonal question, from what i have read they can be used in standard headlights but with mixed longterm success. The HIR bulbs run much hotter and having the IR reflected back into the globe means the socket it connects to must be able to handle the heat.
  #5
Old 11-23-2005, 03:44 PM
rycen's Avatar
Halogen Infrared Reflecting supposedly no more heat and draws no more power than regular bulbs but puts out about 60% more light.
here is some info
http://hirheadlights.com/hir%20techsheet.htm
http://hirheadlights.com/USPTO%20HIR%20bulbs.pdf
  #6
Old 11-26-2005, 03:15 PM
Bob Snow Bob Snow is offline
I have been using HIR bulbs in my Honda Accord for months now. There seems to be no downside to these bulbs. They produce significantly more light than the stock bulbs and look a bit whiter because the filaments burn hotter. The envelopes bulge slightly in the middle and have a visible optical coating on them. Since the filament is in the same location as the stock bulb, the beam pattern is the same, but with significantly more light. They are supposed to last just as long as a standard halogen and produce no more heat than stock bulbs, just look at the watts consumed. They are OEM for Dodge Viper. I got mine on eBay and they do require slight modification to the plastic base to fit. They have different size tabs to prevent use in reflectors not specifically designed for them. Hope this helps.
__________________
186,000 miles per
second. It's not just a
good idea, it's the law.
  #7
Old 11-26-2005, 10:53 PM
jashhash's Avatar
jashhash jashhash is offline
The HIR lamps produce 28-32 lumens per watt.
Xenon arc HID lamps produce 70-90 lumens per watt.
__________________
"And these three remain: faith, hope, and love. The greatest of these is love."
Love /verb/: Giving what is needed to those who need it because you care
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
