CandlePowerForums
CPF Only
User Name
Password
Register
Wicked Lasers
Reply
Thread Tools Display Modes
  #1
Old 11-24-2005, 12:17 AM
wuyeah wuyeah is offline
Default How much light does a car produce?
Just one of my curiosity. How much Lumens does a regular car high beam produce? LED or Incandescent.
Does car high beam produce more than Surefire M6??
  #2
Old 11-24-2005, 12:35 AM
Roy82 Roy82 is offline
Default Re: How much light does a car produce?
As a pretty crude estimate, I'd say each headlight bulb (55W) would be say 1200 lumens.
On high beam (60W or a separate 100W globe) it may be higher than 2500 lumens with the 100W. That'd depend on the car what bulb(s) are in there.
Think the brightest the M6 gets, according to Surefire is 500 lumens. So I think the car wins.
Someone else will probably have some better numbers than me, hopefully I'm not too far off and embarrass myself on my first post!
  #3
Old 11-24-2005, 12:56 AM
Lynx_Arc's Avatar
Lynx_Arc Lynx_Arc is offline
You can take as a rough estimate the wattage of the bulbs and compare. Car headlights range from 50watt low beam to 100watts high beam. The focus on headlights it less than nominal for a flashlight as a lot of light is scattered purposely on low beam and a tighter flood on high beam that most flashlight makers find useful on high output lights such as the thor versions. Comparing them to flashlights is not entirely easy or useful.
__________________
  #4
Old 11-24-2005, 01:21 AM
illuminator196972 illuminator196972 is offline
Roy I would say 500 to 1000 lumens on high beams.
__________________
flashaholic
  #5
Old 11-24-2005, 04:50 AM
270winchester 270winchester is offline
H4 automotive bulbs routinely go up to 130watt don't they? I have seen a lot of cars with bulbs that rival that of the thor spotlights, but two of them. Well, that's before car companies widely started using HID modules....
__________________
"a government and its agents are under no general duty to provide public services, such as police protection, to any particular individual citizen." -Warren vs District of Columbia, after three women were raped, beaten for 14 hours and police never came after numerous 911 calls were placed
  #6
Old 11-26-2005, 03:04 AM
bfg9000's Avatar
bfg9000 bfg9000 is offline
Does indeed depend on the bulb and reflector. An H7 is rated for 1500 lumens from 55w, while most other 55w bulbs deliver ~1200. Installing the same bulb in a low beam reflector will result in additional losses out the front from the cutoff shields.
For comparison, a standard H2S HID low beam lamp is rated for 3200 lumens/35w.
  #7
Old 11-27-2005, 01:31 AM
Blackbeagle Blackbeagle is offline
For what it's worth, the older literature for the MCharger and other lights similar to it used to refer to the typical (for the time) sealed beam headlights as having about 20,000 CP.
  #8
Old 11-27-2005, 01:45 AM
nemul's Avatar
nemul nemul is offline
i seen 160w H4's on ebay... i could turn my 10cp into a 20cp.. lmao
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
