100 Watt 10,000 Lumen LED 'DayMaker' Flashlight Build
jayrob
Well-known member
Supporter
Northern CA U.S.A.
Version 2 here: 100 Watt LED Version 2
So I saw
a Youtube video of a guy that made a flashlight out of one these 100W LED's you can get on Ebay for about 5 or 10 bucks...
These things fit perfectly onto a computer CPU heatsink with fan and it's the perfect cooling for it.
Super flood turns night into day. I think these things are made for parking lots, etc...
The Youtube build I saw was awesome, but there was one thing that I didn't like about his...
He used a round pack of Li-Ion's that definitely blocked the air flow through the tube, which would not be good cooling, and it would also hurt the fan...
So...
Since I already had a CPU heatsink with 12 volt fan, plus various other supplies laying around, I set out to make myself something similar but with a LiPo pack which would lay flat inside and allow plenty of air flow. :)
Here's a short video demonstration showing air flow through the tube:
Lipo pack:
My build is designed around this battery which I already have a nice balance charger for my other Lipo cells I have for my RC heli's...
All parts can be picked up for very cheap! (except the battery - that's the only real expense. I paid $60 for the battery)
I molded some easy to make battery mounting plates with some of that 2 part marine putty...
Details:
That large boost driver was only 13 bucks. It has Voltage adjustment as well as Amperage. So you can dial your LED in perfectly.
The LED needs 36 Volts and 3 Amps. My Lipo cell draws about 7.8 Amps at full charge in order to boost to 36 Volts at 3 Amps...
The smaller driver is a buck driver for the 12 Volt fan. It only cost about 5 bucks. The fan only draws about 380mA.
I have a voltage monitor on there as well but that only draws about 7mA's.
Battery voltage monitor color code:
Bright blue - Full charge
Cyan - Very good
Green - Good
Yellow/Amber - Low warning
Red - Batteries low
My total current draw for everything is 8.2 Amps at full charge.
Balance charge plug out the back, and charge plug out the front...
Handle mounted perfectly balanced... :) (total weight - 5.4 lbs.)
Night turns into day! :cool:
Got a second lens so I could experiment with sanding the back side...
Wet sanding did not work too well so I put a very light etch with my sand blaster:
The yellow ring is now gone... (Spot on the wall at 4' distance)
Stock lens:
Etched lens:
Click here to see my list of projects and tutorials! :)
HarryN
Well-known member
Pleasanton (Bay Area), CA, USA
That is a neat home build. What is impressive to me is how easy it is for a home builder to make the body for it. I have spent countless hours and way too much money getting aluminum machined.
Is the driver a standard "brick" size?
One small improvement to consider is a screen of some kind for the air inlet side. Even a coarse screen will keep out a lot of dirt and fibers.
Harry
jayrob
Well-known member
Supporter
Northern CA U.S.A.
Harry
Glad you like it!
The LED driver came with a finned heatsink that I had to modify in order for it to fit the tube. It is stacked on top of my Lipo cell.
The fan driver also came with a tiny heatsink that I thermal glued to the chip...
Ladd
Well-known member
US
Great build. Enjoyed the excellent pictures and description. Thanks for taking the time to post this!
jayrob
Well-known member
Supporter
Northern CA U.S.A.
:thanks:
My pleasure to post...
Really love this build/project. Amazing flood of light! :)
I've been turning this thing on every chance I get...
1st charge holding up a lot better than I had anticipated.
Also the voltage does not 'sag' at all with this Lipo. (I can test voltage before and during operation right from the charge plug)
jayrob
Well-known member
Supporter
Northern CA U.S.A.
:bump:
Got a second lens today so I could experiment with sanding the back side...
Stock lens:
Etched lens:
Adding to OP...
