100 Watt Maglite Parts List
Goofy_Goober
Pennsylvania
I made a post on Reddit about this light, but I'll describe it here. This is a 3D Maglite modified to use an Osram 64625 (or similar) halogen bulb paired with a PWM dimmer for brightness control. It's powered by 3x 26650s, but can also take 21700s.
There were a couple people interested in having a guide/parts list for this light, so I'll leave one here for anyone curious. This won't be terribly in-depth, so you can ask if you have any questions.
PARTS:
Lens: https://lumencraft.com/led-upgrades-for-maglite/56-glass-lens-for-maglite-94-transparent.html
Reflector: http://kaidomain.com/S006166-KD-M-g-OP-reflector-V3_1-15mm-Opening
The glass lens and aluminum reflector are needed to withstand the heat of the bulb, the stock plastic ones will melt pretty quickly. These are easy to change out, they just drop in. If you get a different reflector, make sure the opening is wide enough for the bulb.
Bulbs: I've used Osram 64625, 64623, and 62138, which are all 100 watts. The 64623 is a 2000 hour bulb with a nominal output of 2800 lumens and a temp of 3300K. You could probably drive it with 4 26650's if you wanted.
The 64625 is a 50 hour bulb with a nominal brightness of 3600 lumens and temp of 3450K. This is similar to the 64623, but trades lifespan for efficiency.
The 62138 is also a 50 hour bulb, but the filament is smaller, and oriented perpendicular to the base instead of parallel. This allows it to be focused much better and has a better beam shape.
Note that these bulbs will last substantially longer than rated when run at lower power.
Socket: https://www.candlepowerforums.com/threads/g6-35-ceramic-socket-by-fivemega-2.480924/
This is a GY6.35 ceramic socket with a brass base, which allows for any 12 volt GY6.35 bulb to be used. You will have to cut the bulb tower off of the switch assembly to install this, so this is a permanent modification. I found that the base slid down the barrel easier with some oil on it, but be aware that this part will heat up during use.
For reference on the switch modification, see this video:
For the switch, I soldered one wire to the negative contact and one the the top switch spring. Be careful to ensure these wires can't contact and cause a short circuit. I drilled a whole through the body of the flashlight on the side opposite to the switch, above the switch assembly but below the base of the head. It should be just big enough for all 4 wires. It would be a good idea to smooth down the sharp edges to prevent the wire insulation from being cut.
Dimmer: https://www.amazon.com/gp/product/B0BVR5G73J/?tag=cpf0b6-20
The dimmer is simply zip-tied to the body of the flashlight, 90 degrees offset from the switch. You could probably mount it more securely, but I haven't found it to be a problem. The wiring is pretty self-explanatory, the bulb is wired to the side that says "LED". + and - don't matter for this side since the bulb is just a glorified resistor. I used the dimmer on the lowest frequency to reduce losses, but you could use it on any frequency. Even at 800 HZ, the switching is vastly too quick for there to be any sort of flickering. The filament can't cool enough in 1/800th of a second for any change in brightness. The only issue with this dimmer is that you can hear the PWM as a soft buzzing at the selected frequency, I haven't found any way to prevent this.
Tail Spring: https://lumencraft.com/led-upgrades-for-maglite/62-shorty-tail-spring-for-d-cell-maglite.html
With the stock tail spring, there won't be enough room for the batteries. This short tail spring is recessed in the tail cap, and takes the place of the spare bulb (which won't be needed). You will need to use a dremel or sandpaper to remove the anodizing inside the tailcap. I found that this spring would heat up substantially with full-power use, so I soldered a piece of solder wick between the top and bottom of the spring to "bypass" the spring. I also applied carbon conductive grease to the bottom of the spring to improve the connection.
(Yes, I made a mess with the grease)
Batteries: 26650 batteries are thinner than Ds, so you will need some sort of spacer. I used 1" SCH 40 pipe. The tolerances on the inner diameter are very close, so I'd recommend taking a 26650 and checking if it fits. I found that some pipes in the same batch would work, some wouldn't. I've also used 21700s, however, these are longer so the lengthwise fit is very tight. I wrapped them with wire to get them to fit inside the pipe.
Positive Contact: https://www.amazon.com/dp/B09YCQC2YF?tag=cpf0b6-20
Flat top batteries won't touch the positive terminal on the underside of the switch assembly, so one of these it needed to make contact. I found that they weren't needed between cells, even though they are flat top.
OTHER COMMENTS: The batteries together have a nominal voltage of 11.1 volts, with a max voltage of ~12.5 volts. Additionally, depending on what batteries you use, there will be a voltage sag of 0.6-1.2 volts at full power due to internal resistances. This means you will likely get less than the rated bulb output. Despite that, this light is still brighter than my car's high beams, so it's not that big of an issue.
At full power, the head & socket will heat up substantially, and the body near the switch will get too hot to hold after several minutes. There's no thermal regulation, so you'll just have to feel when it gets too hot.
I've always wondered something. Modders almost entirely focus on D-cell Mag-Lites rather than Magchargers that're already geared towards hot halogens. Is there a technical reason for this or do people tend to ignore them?
I guess because they're not as common. Most of the parts I found were for D Mags, and the internals are pretty simple. All the Magchargers I see sold now are LED. I just recently got into this, so I'm not sure though.
Would be nice to have everything inside the light.
Stock switch assembly is almost the same size, as the outside dimmer.
So getting everything inside
(+ shorter; to not have to mess around with the tail cap and spring)
... would be the perfect mod
Ya you just described the phd. But that takes a lot more engineering and creating new stuff from scratch
Unfortunately when it comes to incas., no one is interested in doing that nowadays.
I gotta say your post put a huge smile of nostalgia on my face. When hot wire Mag Mods were all the rage when I got into this hobby 20 years ago.
You've found a sweet spot with the 100W Osram bulbs and I applaud your ingenuity of using PWM as a dimmer even though the external module is a bit ungainly.
There used to be specialized mod gear like voltage regulators with soft start and charts with suggested overdrive voltages leading to dozens of combinations of high output incan setups. Over time many bulbs were discontinued (a moment of silence for Welch Allyn) and it seemed incan mod interest seemed to wane but I have great memories of my hot wire days of old.
Back then the power source was commonly packs of NiMH cells but I love the modern twist of using 26650s. Your design is solid down to the tailcap spring mods and bypass.
Overall a standing ovation from me on your creation! Great job 👏
Thank you! I know the external dimmer is a bit goofy, but that's the only way I figured I could get continuous, full range dimming.
Try to locate a AW electronic switch, it is a dimmer that is made to take place of a oem switch, with a bipin bulb tower, it is completely enclosed.
However dimming a bulb gives you a dim yellow light, I had that switch, 2 lower modes look like batteries are low and very low.
Is that something made for a Maglite?
They're a drop-in replacement for the D-size stock switch that integrates soft-start switching, dimming, and flashing modes. Incan tech on the forums peaked around 09-12 at an almost unbelievable level of refinement. The AW switch looked practically primitive against some of the other programmable regulated drivers. Picture of mine for reference.
Probably hard to find something like that today, maybe I could design something...
