1250 Lumens for 19.95!!!
1250 lumens/.15 = 8333 lumens per watt, or almost ten times the theoretical maximum efficiacy of a 100% efficient monochromatic green light! At $20 bucks such a product is a bargin, if even just to reverse engineer it and understand what sort of exotic physics they discovered to make it work 😀
Serously though, even if they meant 12.5 lumens, at 83 lumens per watt (I assume this to mean they're driving the LED at 40mA x 3.6V) might be possible if they are using the very best 5mm LEDs available, ie the expensive ones with 4 dice inside, but I somewhat doubt that's what they're using.
Their package reads: Power/Lumens.....0.15w/1250.
Maybe they just made a small error and transposed the two numbers? ;-)
A highly ineffecient bulb, if you ask me - 1250 watts to get 0.15 lumens.
My guess is that they probably meant 12.50, even though that is a bit much for a 5mm at 40mA, it would be a closer match than 1.250 (and three digits past the decimal is way too precise) -- they probably DID mean to overrate it, just not by so much.
I don't think even the Nichia CS could pull off 12.5 lumens at 40mA.
I think you're right.
IIRC the Nichia CS emits about 3 lumens @ 20ma, and the efficiency drops as the current goes up, so somewhat less than 6 lumens @ 40ma.
The four-die WahWang will do 12 lumens at 80 ma, though.
Toshi
:lolsign:
I think it could be in Lux too @ some distance 🙂 ...
In my opinion it must be a type error....
how it is possible!? And for only 19.95.
It must be 12.5 or 1.25 lumen but I might buy it :bumpit:
19.99 for 1250 lumens.......and to think i just spent 30 bucks on a rexlight. man, if i only knew, i wouldnt be wasting my money on that rex. 😛
