I'm looking for help figuring out what size battery and solar panel setup would be sufficient for my needs.
Requirements:
-Reliable/weatherproof LED setup to light area from 25-100 yards out.
-Affordable solar panel setup with battery
-RED
Here's what I have as possible components for this setup:
-Battery: I have a 12V 18Ah/20hr AGM battery taken from a portable car jumper. From my research this battery type is perfect for solar setups.
What I'd eventually like to find is the minimum requirements for a battery to power this system. (6v possible? less Ah? etc.)
-LED: Must be red or green and project so figured the cree xp-e's would be good. From www.ledsupply.com I found the 3-up red's might fit the bill. If there are other suggestions please let me know.
-Driver: I plan to use a puck to drive them at 700mA each. According to the website and my calcs thats 6 LED's at 700mA = 4200mA = 4.2A. The Vf for the LEDs would be 13.8V (6 * 2.3Vf). Not sure if these calcs are wrong, please correct me if I am.
-Heatsink/Housing: Might use the ones shown on ledsupply's website, but may machine/find my own. I do like how their setup just screws into normal junction boxes, would be easier to fabricate the enclosure when done.
-Solar Panel: 12V 5W should be sufficient? Overkill? Got a little lost doing the calcs for this but here is some info. Will be using a dusk-dawn switch so run time on the lights will be ~9hrs each day. The solar panel will be getting ~10-14hrs of sunlight a day (Texas summer). But I suppose using the low end would be better ~10.
So here are my a few of my questions:
1) Can someone show me the calculations to show my power usage per hour and how that translate to picking a battery and solar panel setup?
2) Is my current battery (12V 18Ah/20hr) sufficient for (2) 3-up cree xp-e driven in either 350mA or 700mA (calcs for both?)?
3) Would driving the LED's in 350mA be sufficient for my requirements? Up to 150 yards (rated 137 lumens @ 350mA * 2 = 274)?
4) Whats the smallest battery requirements (SLA/AGM/etc) thats cost effective to drive the setup at 350mA and 700mA?
5) Whats the smallest solar panel I could get by for 350mA and 700mA?
I know lots to read...Thanks!
Requirements:
-RED
