Sponsor 15mm Bright COB LED Strip Lights In Stock
ledbe
Check the 15mm bright COB LED strip lights, which will fulfill your need for high illumination and can be used as primary lighting in your space.
Those high bright COB LED strips use chip-on-board technology and allow more LED chips to be arranged on the PCB board to create a continuous bright illumination without light dots. There are 640PCS LED chips on one meter 15mm width PCB board; they are 5 meters per roll, and the minimum cutting length is 50cm. There are 3000K warm white, 4000K natural white, and 6500K cool white colors available. The back has 3M double-sided adhesive tape, making it easy to stick to the place you want to install. Recommend working with aluminum LED channels for better heat dissipation.
Product link: 20W Bright COB LED Strip Lights
