1600Lumens 1X18650 Rechargeable Tactical Light - Klarus XT2CR Release
Status
Not open for further replies.
klight
The King of Tactical Lights 2017
One-Touch Strobe, compact rechargeable tactical flashlight XT2CR is released today.
CREE XHP35 HD LED/1600Lumens
Extremely compact but intensely bright, Mini Rechargeable Tactical Light XT2CR delivers 1600Lumens high output and illumination up to 240meters due to the integration of CREE XHP35 HD LED and Klarus High Efficiency Circuit.
Compact Size/Dual-Switch
Weight of 88.5g(w/o battery), size at 139x25.6x25.4mm for the perfect size, dual-switch tactical tail cap design with a primary switch with momentary on, on/off and constant-on functions, and a MODE switch with one-touch strobe and one-touch low functions, XT2CR is very comfortable for one-hand operation, easy & fast for one-touch access and accurate tactile switching.
Extremely Compact/Multifunction
Though extremely compact, the mini rechargeable tactical flashlight XT2CR is designed with multiple functions, include One-Touch Strobe, One-Touch Turbo, one-touch low, SOS, Intelligent Temperature Protection System, Intelligent Battery Load Check System, Battery Capacity Indication, fast USB charging, quick mode change, constant current, compatible with multiple batteries, etc.
Programmable/Dual Settings
The mini rechargeable tactical flashlight XT2CR is programmable with dual settings. When under tactical setting, the one-touch strobe feature can disorient dangers quickly, one-touch turbo feature can help illuminate distance clearly. And when under outdoor setting, one-touch low feature delivers soft light that protects eyesight when reading, one-touch turbo and SOS features aid in rescue efforts when in dangerous environments.
Rechargeable/Micro-USB Port
The mini rechargeable tactical flashlight XT2CR is rechargeable, it is designed with a Micro-USB port for fast charging via wall outlet, car charger, PC/Laptop, or powerbank. The charging port has three-tier protection, reliably guard against moisture, dust and sand.
Digital Intelligent Charging Module/Intelligent Battery Capacity Indicator
XT2CR is integrated with a digital intelligent charging module with real-time monitoring of charging status, prevents overcharging, charging current up to 1A, safe and fast. With an intelligent battery capacity indicator to show battery status, it will be easy for to know: Red for charging, Green for fully charged, and Flashing Yellow indicator for inspection required. And you will be aware of light status by checking the state of battery charge at anytime. Green means battery capacity over 70%, Orange means battery capacity 30%-70%, Red means battery capacity less than 30%, but if Red and flashing, it means battery capacity less than 10% and requires immediate replacement.
ITS(Intelligent Temperature Protection System)
The mini rechargeable tactical flashlight XT2CR also utilizes Klarus ITS(Intelligent Temperature Protection System) to monitor internal temperature and adjust output of maximum brightness, protects LED and internal components to ensure safety, stability, optimum performance and user comfort.
Same with Klarus Searchlight G35, Programmable Tactical Light XT11GT and Magnetic-charging Tactical Flashlight XT12GT, XT2CR is the fourth Klarus light that incorporates with the intelligent battery load check system. With high-performance 3600mAh Panasonic-core 18650 battery included( featured in TESLA electric cars) to deliver 1600lumens, XT2CR also has broader battery type compatibility with greater protection for batteries, it is compatible with all types of 18650 Li-ion batteries and CR123A batteries.
Designed for Safety/Multi-Tier Protection
Designed for safety, The mini rechargeable tactical light XT2CR has multi-tier protection. It has reverse polarity protection to prevent circuit damage from incorrect battery orientation, front and rear internally mounted springs to protect against shocks and drops.
Extremely Waterproof/Ease of Mind in Any Weather
The mini rechargeable tactical flashlight XT2CR is extremely waterproof, waterproof level is IPX8, it can be put in water and down to 2meters and suitable to use in even the most severe weather conditions, you’ll have ease of mind in any weather with this light by your side.
Ingenuity in Craft/Ergonomic
Crafted with ingenuity, the mini rechargeable tactical flashlight XT2CR is an ergonomic tactical light even from the design stage.
6061 Aerospace Aluminum alloy construction, mil-spec HAIII anodizing; Durable stainless steel strike bezel, shock and abrasion resistance, can be used as a defensive tool in emergency; Patented dual-switch tail cap, easy to operate; Stainless steel clip, easy to carry; Grooved texture design, comfortable and slip-proof.
Multiple Applications
The mini rechargeable tactical light XT2CR can be used in various ways, it can be used for law enforcement, search and rescue, hiking, cycling, camping, expedition, self-defense, SOS, etc.
4 Lighting Levels/2 Flash Modes
The mini rechargeable tactical light XT2CR has 4 lighting levels and 2 flash modes according to the ANSI data.
Extreme high mode at 1600lumens with runtime for 1.2hr, high mode at 400lumens with runtime for 4hrs, medium mode at 100lumens with runtime for 14hrs, low mode at 10lumens with runtime for 200hrs, strobe mode at 1600lumens with runtime for 2.4hrs, and SOS at 100lumens with runtime for 42hrs.
Parameters for Klarus XT2CR
Prameters for XT2CR:
• Input: 2.5V-8.4V
• Battery: CR123Ax2; 18650 battery(protected)x1
• Charging: 4hrs (1A, 3600mAh)
• Reflector: Mirror-polished
• Switch: Dual-Switch Tail Cap
• Size: Head (26.5mm /1.04") x Body (25.4mm/1") x Length (139mm/5.47")
• Weight: 88.5g (w/o battery)
• Material: 6061-T6 Aluminum alloy
• Waterproof: IPX-8, waterproof down to 2 meters
• Lens: Hardened, AR-coated lens, scratch-resistant
Package for Klarus XT2CR
Standard package of XT2CR:
1x XT2CR
1x 18GT-36 18650battery
1x Holster
1x Layard
1x O Ring
1x Micro-USB cable
Optional Accessories:
Rail Mount
Charger
TRS1 Remote Switch
Re: The King of Tactical Lights 2017 - Klarus XT2CR is Released Today
Which Cree XHP35 HD E4 LED is being used? Need more specific information on the CCT, 5700K or 5000K? Sure wish the 5000K C4 group was chosen.
i also see in some videos the XT2C-R with the XPH35 HD with 240 meter beam distance and in some videos the XT2C-R with the XPH35 HI with 310 meter distance. Do you know if Klarus will make 2 versions? I think that the HI is better with 310 meters right? I need to have the HI version hope this will come!
Too many choices of great models from them. I wish a local place carried these to hold and try out
I quite like the look of this light. A high output 18650 tube light with very flexible user interface!
I've already ordered one for myself, can't wait to try it out!
KLARUS... a very unique flashlight brand name.
i dont owned any Klarus light yet, but im amazed with new models this
past years. They make lights like a masterpiece.
I always wanted to have the badass XT12GT or XT11GT, and cool
and drooling little torch with a big punch XTIC.
And now the new KLARUS XT2CR TACTICAL, its even more drooling and
awesome compact light! Another badass from Klarus.
There's so many features of this light that i love. A lot!
It CREE XHP35 HD LES that can punch up to 1600 Lumens with a
single 18650 Li-on battery. And yes, it comes with the battery inside!
The "R"?... means it has a micro-usb charging port. Charging capability is
now more important when purchasing a flashlight.
KLARUS is now more innovative with their new models. Like its bigger
brother, the XT2CR has a unique Dual Tail Switch for quick access to special modes.
I like using strobe, specialy using as a self defence. And using thise switch you can make
the XT2CR a programmable to Tactical and Outdoor settings. And thats very cool!
IPX8 water resistant,
It has Digital Intelligent Charging Module,
Intelligent Battery Indicator,
Intelligent Temperature Protection System (ITS).
Strike bezel for also self defence. Slim and compact perfect on any hand size.
The KLARUS XT2CR is the face for the Tac-Outdoor flashlight. And this brand
absolutely kicking the other brand aside.
You cannot go wrong with KLARUS LIGHTS, theyre on top now.
Thank you KLARUS, for making our world brighter and more exciting for
flashlight freaks like me.
KEEP IT UP GUYS!
birdhauz24
philippines
Hello, that's good question:twothumbs both E4 and C4 are applied to XT2CR, 6500k & 5000k
Hello, that's a good question:twothumbs both E4 and C4 are applied to XT2CR, 6500k & 5000k
Status
