VanIsleDSM
I'm glad you enjoy! Wait until you see it at night, it's a field lighter.
The optic is a Khatod Italian made 10 degree FWHM beam with an XPE, so slightly wider with an XPG. It is the tightest beam of any small triple or quad optic, and cost 3X as much as the Carclo optics that try to compete with them.
The driver does have memory, and a low battery warning for use with unprotected cells.
I am surprised that you needed a spacer though, that larger head that you are using must have slightly more space in it. What type of cell are you using?
I do need to get all the final specifications up. The drop-in is nice and heavy because I have paid attention to every little detail while engineering it to make it as good as it can possibly be. The reason there is no spring on the positive contact, is that there is no need for one, there is already a spring for the switch. This allows me to drop the driver down, and create a very thick heatsink base for the LEDs, 7.2mm thick, over a 1/4". Even the aluminum version has a nice weight to it.
I'll have your threaded FETtie in the mail asap, just had to get the thermally enhanced MOSFETs in. I would like to make a forward clicky version of the FETtie for those that prefer. Personally I like reverse clickies, so you can change modes without clicking off the light, but I understand that there are those that don't. The problem is that reverse clickies are shallow enough to fit in with the battery and elctronics.. just barely, and I mean barely fit. I would have to find quite a small forward clicky to be able to utilize it, but I'm sure one exists.
