VanIsleDSM
I must have calculated the angle wrong, I can't remember what the decimals were, but from your measurements I came up with 9.xx degrees I think, I don't have it in front of me.
So.. it should be no big deal, take a little more material off at the taper and it should sit right in.. I know it's not going down as far as I designed it to, because the contact, the lowest part of the driver, is supposed to drop in past the spring perch that holds down the 18650, so it will make contact when the material has been removed to allow it to do so.
I should have my 6P Defender soon, I ordered from a place only an hour and a half ferry ride away, so it shouldn't take too long, and then I can perfect the fitment.
I am just curious about whether there is a gap with the Malkoff and the Solarforce, as without the grounding spring, the small gap ensures that the head when screwed on, pushes the drop-in onto the spring perch to make good electrical contact. If there is no gap, there would be no pressure, just the fit of the heatsink on the walls.
I think it is prudent to either design this drop-in with a small gap, so it is pressed against the spring perch for contact, which means it would have to be large enough to have a small gap on the Solarforce, which would mean a slightly larger gap on the Surefire, or to use the grounding spring to apply pressure for current transmission and go for no gap.
I would like to make the drop-in with no gap, as I kind of have a fetish for OEM quality and fit in all of my hobbies. This requires me to make the custom spring, and will add some expense, maybe $10 or so overall vs no spring?
How important is "the gap" to all you CPFers out there? What would you like to see done?
list.
