worst spec everHi
I'm looking for (and can't find yet) a driver for a XM-L U2 with less than 17,0mm diameter, Input should be ~3,6V to any, and output must be real 3500mA max.
Thanks in advance!
I have had really good luck running the Nanjg 105c with 10 7135s ie: 3.5amps. With the U2 XML they are very bright, but they do generate some serious heat so you must be careful of that.worst spec ever
Why? Please explain better!worst spec ever
Are you opposed to building the driver up to meet 3.5A? Do you need boost/buck capability to maintain constant current?
What I am proposing is a NANJG 105C driver (8x AMC7135) and adding 2x AMC7135s to it. This is one I made for 3.15A.
This is a very reliable way to achieve your objective until such time the battery voltage drops below the required Vf to maintain this current. At 3.5 amps, that will be pretty soon. I think I measured the Vdrop across the regulators at ~0.1V. I used Arctic Silver epoxy to hold the 7135 in place and share the heat. You will need a good boost driver if you need to maintain 3.5A to the emitter. I haven't found a good driver that will do that in a low profile 17mm formfactor.
I just took these, I hope they help.
Each chip adds 350mah, just bend the 3 little tabs down and piggyback them. I have made 2 4.2A drivers now this way.
I get my chips (and drivers) from Illumination Supply. Craig is a CPF sponsor/retailer. He sells the chips for .50 a piece.
I just ordered 30 more of them, and they have fast shipping too! I get my orders from them in 3 or 4 days usually.
The driver in the pic is a 5.6A driver that has 4 chips added on the top as well as 4 chips added on the bottom!
I am going to make a 1.7A driver for an XP-G next, it should be almost 500 lumens with great throw.
Feel free to PM me if you have questions!
Just buy extras, if you mess up you will only be out $7.00 or $8.00.
At 3.5A drive, an XM-L could have a Vf of 3.4V. Add in the 0.12V overhead for the 7135 and you might need a min of ~3.5V to reach full regulation. Realistically, you will need more than that because your flashlight (I assume that this is a flashlight application) will have parasitic resistances (e.g., from spring contacts, battery/battery contacts, thread contacts, switch contacts). At 3.5A, if the parasitic resistance is even 0.1 ohms, you need another 0.35V, for a total of ~3.85V. Even if you use 1xIMR26500, your run time in full regulation is going to be woefully short.
If you are powering the XM-L with a bench supply that allows you to dial in a specific input, then you're all set. If you can feed the driver 4xD NiMH cells, then you should have plenty of voltage to stay in regulation (at the expense of relatively poor efficiency and thus that much more waste heat generation).
But with 1xLi-ion, if you are expecting or wanting decent run time in regulation, you probably won't get it. Maybe if you paralleled a bunch of IMR26500s....
