18650 and 26650 batts + a good charger (newbie)
super kermit
I am looking for good high quality protected batts.
18650 and 26650 for my ebay dive lights.
I also need another charger to charge both types.
banggood.com I have bought from before
Are the below a good choice?
26650 batts;
http://www.banggood.com/26650-KeepPower-4500mAh-Protected-Rechargeable-Li-ion-Battery-p-918313.html
http://www.banggood.com/Genuine-Oli...argeable-Battery-With-Protected-p-917846.html
18650 batts;
http://www.banggood.com/2PCS-NCR-18...ted-Rechargeable-Lithium-Battery-p-90990.html
Charger
Confused
kj2
The Netherlands
For the 18650, I would go for Eagletac or Olight batteries. But be aware, that 26650 battery from Olight isn't standard. It has + and - pole at the same side. So can only be used the the appropriate light. Those Keeppower batteries are good :)
thedoc007
Michigan, USA
Also check out the Nitecore Intellicharger. It is slow...so be aware of that. But if you don't mind waiting, it is a good charger. Terminates properly, dead easy to use, will take just about anything except LiFePO4, 10440 to 26650. Will also charge NiMH or Ni-Cad batteries if needed, AAA to C.
super kermit
Nitecore I4 V2 Li-ion Ni-MH Ni-Cd Smart Battery Charger4-channel charger / version 2.0
I have the old V1 - awesome thing.
Where should I buy V2 from (ie sellers on forums?)
Any links to specific batts?
wrhaliburton
Currently using the Nitecore inellicharger i4. Looking at getting the new digicharger, but price a little high.
yellow
Baden.at
just an idea:
You dont need to get a new charger, just a slight modification to the VP1.
From the beginning I really hated those totally unnecessary "extensions" at the "cell opening" the VP1 has.
They feature no use at all and prevent the cell to be gripped good - often they slip out of my fingers and get shooten away by the spring pressure.
Solution: cut them away with a file.
Happens that this mod opens space for 26xxx cells
PS: test Your 26650 cells!
at my uses - XM-L on normal current - the ones I have are WORSE than most 18650s.
They do not give the same runtime, or - at best - just a tiny bit more.
So - to me - it makes no sense to bring a much bigger and heavier light, for nothing.
PPS: when I have time, I will close the holes in the VP1 with a plastic sheet glued over the holes
