18650 battery weights
Flint Hills
Hi everyone,
Anyone else a weirdo that’s concerned with weight? I was hoping people could weigh and share different brand 18650 batteries and share the weights here. I’m interested to see if there’s much difference, looking for the lightest weight.
The only ones I have are the pink Sanyo sold by Zebralight and they are 47-48 grams.
aznsx
Phoenix, AZ USA
Hi everyone,
Well you may be weird, but if so, you're probably at the right place!
All I can tell you is that when I go to 18650s at the Battery Junction site, they seem to list weights in their specs for all the ones I checked (although I didn't check them all). The ones I noticed when checking for that seemed to be within a couple of grams range, and that may or may not be due to the 'protection circuit' variable (&/or USB charging in some cases), but the variance may be larger than that with some. Have a look.
kerneldrop
South
I must ask just so I know the why behind the weight concern…why are you concerned with weight?
I know ultralight hunters that go crazy over shaving ounces from their rifles, so I get it.
bykfixer
My own little Idaho
My son was concerned with shaving grams in his 2900 pound car at one point. No carpet, no back seat, all kinds of stuff so it could go zoom a little quicker.
If I recall correct moderator Empath had a quest for saving weight when packing for a long hike or something.
Stefano
Italy
The weight of the 18650 is the one with a difference of 5 g and no more.
Out of curiosity I have now weighed some batteries using a jeweler's scale that I use for vitamins, it is very old but it seems to work very well.
I weighed these batteries (they all have a sticker on them attached by me with the year of purchase unless otherwise specified)
LG MH1 = 44,55 g
NCR18650B = 45,80 g
Samsung 30Q = 45,81 g
Sanyo GA = 46,90 g (without sticker)
KeepPower 2600 mA (protected) 46,36 g (without sticker)
Fenix 2600 mA (protected) 47,99 g (without sticker)
Ampmax 3100 mA - (protected) 46,66 g (without sticker)
The heaviest seems to be the Fenix but they have an "armor" that makes them more robust in case of a fall
But you can find the weight of the batteries on its official data sheets or on the know danish website - a sample link:
The weight of the batteries is irrelevant unless you carry 10 batteries but even then you may only have 50 grams more or less.
jtr1962
Flushing, NY
My only interest in battery weight is to calculate energy density. Beyond that, it's not that important. If a person takes a good bowel movement that's the weight of half a dozen or more 18650s. It doesn't matter much if the one in your flashlight is a few grams lighter or heavier.
bykfixer
My own little Idaho
I lost 2 pounds by having a BM one day. I was in the midst of some mental stuff and hadn't eaten well recently. I went to a place that knew that and fed the residents all you can eat buffet style. I was gaining weight daily. I had gained 16 pounds in a few days but had not had a bowel movement. One morning on the way back from breakfast I weighed myself when the urge struck.
After a gigantic load was expelled I stepped back on the scale and was 2 pounds lighter.
fulee9999
Here are my measurements, three unprotected and one protected cell
Sony VTC6 - 46.8 g
Efest ( 3500mAh ) - 46.4 g
Sofirn - 47.9 g
Sanyo GA - 49.3 g
xxo
Higher capacity cells usually weigh more and protection circuits/built in USB chargers add a bit of weight. Still 18650's don't seem to vary more than about 10 grams.
Lynx_Arc
Tulsa,OK
How many 18650s did you eat?
KITROBASKIN
New Mexico, USA
Cheapo rinky dink 18650 battery included with a bright green laser says 3000 mAh but weighs about 20 grams less than a vintage protected AW 3400 mAh.
Lynx_Arc
Tulsa,OK
Cheapo rinky dink 18650 battery included with a bright green laser says 3000 mAh but weighs about 20 grams less than a vintage protected AW 3400 mAh. View attachment 31854
I have a pinkish purple 18650 that was included with a battery fan that felt almost like it could float it was said to be 2200 or something like that but only tested to 1000mah.
aznsx
Phoenix, AZ USA
Having 2 bad hips and doing a fair bit of hiking around out in the 'real world', I try to save any weight I can, which is one of several reasons I for example do not carry any Ti flashlights, or any metal heavier than 6061 T6. That said, as has perhaps already been alluded to: in lieu of any facts or evidence to the contrary in a specific situation, when it comes to energy cells, my automatic assumption is that 'heavier is probably better', and lighter is probably best considered suspect, or at least questionable. I don't apply this to all 'things', but would specifically in the case of standard form factor energy cells. If a cell is lighter than average for its type, I would be asking myself 'why' and 'how'.
