Lightfoot98
Sounds tempting - how many batteries can you use? If it is 1 - 4 as you wish then I might buy one.
For charging - is this one channel? How many at a time - 1 to 4 or 1 only or 4 only or what?
I'm always interested in more options, I've got plenty of rechargeable batteries that could be used to provide power to the cellphone.
Use only 1 or up to 4 18650's. I use 4 2200's, so it is a 8800mah usb power supply/charger.
Cells are in parallel, so they all charge at once, I guess a 4 slot 1 channel.
Has a td4056 chip for charge regulation, so it is a true CC/CV algorithm.
With a 1amp 5v input, it takes about 3 hours with a depleted 2200mah cell, with 4 of them it takes around 15 hours and terms at 4.15v
