rmteo
A lens is used.
Help Support Candle Power Flashlight Forum
The flats will be used for model and serial number info.
+1 for Neutral/Warm Emitters. I only buy cool emitter lights if then can be modded/upgraded to a neutral/warm one.rmteo - emittors ... how are you feeling about a warm tint version?
yes!?!
Hmm, there are lots of CPF'ers that dislike reverse clickies, I don't know the breakdown, perhaps there is a poll around here. I'm not a clickie fan, but I do like the forward momentary option from a forward clickie.The LED engine/module is a multi-mode with memory. The switch is a reverse clicky.
I was wondering about your 2xC/3xC research earlier. The 2xC is an excellent form factor, IMO. Is there a chance that the heads will be interchangeable between this version and the larger 'C-cell' versions? (The SureFire C-bodies & FM C-cell/C-body is a good example of this, I have some photos in the thread in my sig that sort of demonstrates the possibilities.)In low mode (estimated 20-25 lumens, 80mA current draw) you can expect close to 30 hours run time with a 18650.
BTW, although I have not mentioned it in this post, this light is being developed in parallel with another line of larger lights for duty use. This larger light is designed for 2C or 3C cells - easy availability of power sources is the primary consideration in this case. It will have similar features and I have been incorporating changes/improvements to it based on suggestions given here.
+1. I can't count how many complaints I've read on CPF that Fenix low's aren't low enough.Hmmmm, was hoping for a low mode lower than 20-25 lumens... That's not even Fenix low.
Because the MC-E would actually KILL the throw. There has yet to be an MC-E that throws like a single die in a similar size head/reflector/optic. We saw this with LuxV versus LuxIII, which is why I never bought a LuxV - they just didn't put as much light down range where I needed it. The physics are still the same now as they were then. Keep the die area small to get a laser throw AND flood with the focusing optic. The XP-G might be the next step up, but that may reduce throw too with it's larger die size. Rebel or XP-E will likely have far more throw, especially when higher bins come out....the super-low bottom end... something like 3 lumens, I think. ... And folks who worry about getting stuck someplace dark for a long time (cavers, hikers, etc.) will really value a super-long runtime ability for emergencies.
Focusing head..... a SUPER idea! Why more companies aren't doing this is beyond me. ... Now, imagine about 600 or 700 lumens out the front from a MC-E, with the same focusing ability. Wow, what a thrower we could have, and yet a perfect flood too.
I for one like Mike's suggestions for names and hopes he gets some lights for them 🙂
I would also like to throw my suggestion in for brand name. How's Exodus for a brand name?
George
