old4570
As the heading suggests , these are the batteries I have found to be , towards the lower end of performance ...
1- BRC3600 - Stopped @ 4.11v [ UF-188 charger ] then 4.19v in my Trustfire Charger [ No sag 4.19v ]
2- Senybor - 4.17v [ UF-188 charger ] 4.2v in my TR-001 [ Sagged to 4.18v ]
3- Spiderfire - 4.14v [ UF-188 ] , 4.19v TR-001 [ Sagged to 4.15v ]
4- Eagletac - 4.17v TR-001 , wont charge higher [ No sag 4.17v ]
5- BRC3000 - 4.13v [ UF-188 ] 4.19v TR-001 [ sagged to 4.17v ]
6- GTL - 4.2v [ No sag 4.2v ]
My WF-188 is a little sensitive to the internal resistance , so gives a small insight into cell quality , so check out the terminations ..
My TR-001 usually goes 4.2v so when cells wont go there ? again , speaks some what for the cells quality ...
Some discharge tests ... Matched to picture
..................... SSC P7 ........ XP-GR5....... XR-ER2 ..........XR-ER2 .........P7
1. Spiderfire .....2.26A.............1.67A........1.45A..............1.5A.............2.15A
2. GTL ............2.86A.............1.83A........1.58A..............1.65A...........2.34A
3. Senybor ......1.96A.............1.5A..........1.4A................1.4A............1.93A
4. BRC3000.......2.08A.............1.57A........1.45A..............1.45A..........2.01A
5. BRC3600......2.21A.............1.63A.........1.45A..............1.57A..........2.07A
6. Eagletac......2.2A...............1.64A.........1.5A...............1.56A...........2.14A
For most of the cells , the performance is very close across the board .. The GTL has the best performance but also the lowest capacity [ possibly 1400mA ] , the Senybor is literally at the very bottom for performance , and the rest are some what close .. As can be seen , as the current requirements lower , the batteries really even out , and picking a clear stand out becomes more difficult .. So bellow 1.5A , there really is very little to set the batteries apart [ OK the GTL stands out , but it has so little capacity ] . Going with a slightly lower current SSC P7 , we can see that the batteries are close again , but going with my high performance SSC P7 we can see where each cell maxes out . [ Again close ] ...
Better Chinese cells will go 2.6A and up to around 3A , and Japanese will go to the other side of 3A ...
When you charge batteries , the thing to watch out for is sag after charging ... Will once again give you some insight into cell quality ...
If there was a barrel , you would have to reach right down for these ones ... :welcome:
