18v Ryobi/Hitachi/Etc bulb upgrade?
Wurkkos
AndyInNYC
This has been asked in the past, but technology advances ...
I have a Hitachi flashlight that uses the drill's battery. The bulb is the standard (for these) 18v .6 amp. Same battery as the Ryobi P700
Is there a brighter than incandescent bulb that people are now using for these? The youtube videos I have seen show a bulb that will likely last longer, but really isn't better/brighter. My eyes are getting old, so I'm looking for an improvement, not just 'different for differences sake'.
Thanks for any input.
flash3b
I have the same kind of light that came in a nice carrying case with a drill, charger, 2 batteries & room for some drill & driver bits. When the original incandescent bulb burned out on mine, I looked for an LED replacement bulb. They're available, for around $10. But then I saw that Hitachi sells a newer LED version of the same light for $14. It fits in the case just the same way & I think the reflector is designed for the LED, so it gives a better pattern than using an LED in the original light. My only disappointment was finding that it just has an on-off switch, so only one power level (very bright).
AndyInNYC
Pity I jumped yesterday and just ordered regular and LED bulbs. I may have to do an Amazon return and replace the whole thing for +/- less.
Thanks for the answer.
Andrew
Chrontius
Orlando, FL
I've been using one of these for years now, and it's just like the most perfect Platonic ideal of a work light I can imagine.
I should really buy some more old Ryobi 18v hosts, because in both joy-per-dollar and utility-per-dollar, these things utterly rock.
Nothing Ryobi has to offer is as good as the old blue anglehead with that monster showerhead lamp, so far as I can tell.
lumen aeternum
Confused, nothing in that page fits Ryobi.
"old blue anglhead" ?????
Chrontius
Orlando, FL
It's something like four generations behind the state of the art, of which I gleefully enjoy one as a four-day power-failure light. But these boys had a big head that unscrews easily for a reflector-and-emitter swap, so…
The trigger is a forward-clicky mechanism, and the head can pivot by 90° if you'd rather hold it like a flashlight than an anglehead, or want to ceiling-bounce some area light.
AndyInNYC
So, thanks to Amazon, I ordered a replacement bulb, a 10 pack of regular bulbs and then bought the new LED version. I never opened the 10 pack.
I have the Hitachi light which came with my drill set.
I bought this LED light: https://www.amazon.com/dp/B07FLLR2TY/?tag=cpf0b6-20
I also purchased the replacement Hitachi which is designed for LED and has a different reflector.
Here are 3 pictures taken in my otherwise dark basement.
One picture is both lights on at once - the new design LED is on the right.
I then took a picture with each light on independently.
While the pictures might not show it well, the new LED is much better - bigger focus and bigger overall lighting. The old light with the new LED isn't bad (and I'd likely be happy if I hadn't bought the new version), but $9 for a new bulb vs $14 for a new redesigned light doesn't make me want to save the $5. Drill Flashlight Compaarison - Old w LED Lights.jpg Drill Flashlight Compaarison - New LED.jpg Drill Flashlight Compaarison - Both Lights.jpg
