1st time recharger, need check on learning / sanity check
jp_over
TX
Friends,
I've read/searched many posts here and received some great advice which led me to get this new equipment:
EagleTac TX25C2 XM-L2 U2 - 1180 Lumens
XTAR VP2 Independent 2-Channel Battery Charger w/ Dual Voltage Display, USB Power Bank for 18560 and similar Lithium Ion and LiFePO4 Cells
AW 18650 Protected 3400 mAh Rechargeable Lithium Battery ( Nominal Voltage : 3.6V / Recommended Charge Rate : max. 1.6A)
Since this is my first time recharging, I'd like to make sure I understand the necessary settings on my XTAR VP2.
From reading the instructions and looking at the battery specifications, I believe I should set the charger to 3.6V and the charging rate to 1.00A.
Confirmation of this would help me out; thanks!
Joe
stokaboka
Florida
Nice choices! I have all three as well and they are first class. Those settings will work fine.
