kosPap
gretings all!
I am new to charging and I am still fighting over my best selection (having some very specific criteria)
anyhow, questions 1
is Adjustable output chargers compatible with solar cells?
for example if a cell outputs 400mAh and the charge uses 300mAh will it work or is it 4cellsx300=1200 mah required?
Also is there a chance a 1000=mAh charger work with taht solar cell, lengthening the charging duration of course? or will the charger not work at all, receiving less than demanded current?
Is it charger depended? (LaCrosse BC900, Maha 8000, Maha 204W, Vanson 3600W)
Question 2:
I am kinda perplexed by top-off charging. reason is taht some charger manuals mention top-off capability and some others do not. I believe top-off is the action of recharging half-used batteries. Will all smart chargers allow that or they won't detect the removed mAh if the amount is small and refuse to charge? Do chargers that offer trickle charging allow top-off?
Wow these were more than 2 question! thanks beforehand guys, kostas
anyhow, questions 1
Question 2:
