2 headed M*g 3 x MCE and 1 x P60 dropin FINISHED :-)
Candle Power Flashlight Forum
Help Support CPF:
The Dane
Denmark
This post got my brain farting like it has been on baked beans for a week :toilet:
showpost.php
http://www.candlepowerforums.com/vb/showpost.php?p=3232199&postcount=6
(Why cant i get this to show as a pic :banghead: )
So today i took a brand new 6 D to the lathe and began working.
A carrier for 4 protected LiIon C cells has been made and i plan to mill a slot for a wire carrying the positive to the opposite end. A ring in one end will carry negative and feed the other end via the body.
The body has been shortened 50mm~2" and recut for another switch and head.
No problems with the mecanical part just fun work.
But what options for lights?
The "max" for the C cells are in the ballpark of 6,5-7A (The circuit kicks in at @8A) and then they deliver @3,5V a piece, so 14V 7A = 98W.
I plan a softstart for the incan (and a regulator for the LED?)
So help me out here fellas, what goes in either end of this ??? (Incert good name here!) light?
Re: 2 headed M*g in progress need input please
Oh Snap, that's hilarious. :crackup:
It's brilliant when you consider the fact it'll be led on end incan on the other.
The power plant is a bit oddball I think. One less cell would of been perfect for a Mag85 incan end. 14v, that's oddball, can't think off the top of my head what hotwire bulb you'd use. Maybe use the regulated incan driver ?
P7 is coming to mind for the led end, but then, I dont' know leds very well.
An amusing but really easy way to wire this up, with two stock switches, and the batteries connecting between the 2 positive points on the switches, you could maybe of run 2 Mag11 in series running at the same time :crackup:That's would be funny.
You can call it "The Axe" :crackup:. How about a white led on one end, and a red on the other.
Very interesting project, and nice work on the head threads by the way 😉
What was the thread for the head?
Will
37,4mm~1.47" x 20TPI
I just measured the other end and copied it for diameter and other dimensions 😱
Sorry no rocket science :sssh:
I expected it to be 20 TPI, but I was not 100% sure. I do a "lot" of the cut/re-thread on the tailcap side (those are also 20 TPI), but I have never done a re-thread hob on the other side. Thanks 😉
You should have an SST-90 at one end. Run it at something ridiculous, like 8amps on high (perhaps use 3 drivers in parallel?), 3 mode so it will actually be usable. On the incan side, try a 35-50w Osram.
I was thinking along the lines of a power end and a feeble end, ie
5xMCE, 12V 75W bulb or something other and a XPG.
I have a M*g with 3xMCE so a SSR-90 will be exactly the same just different!
I would prefer to go bulb to minimize cost (5xMCE=@80-100 and 3xSSR90=@150 and i'm broke!) but sugestions are appresiated and 2'hand LED's i can afford would be great:twothumbs
Maybe HID but i dont know where to get a kit with a round ballast!
For HID, look up the WA Solarc -- the old ones were 10W, the new ones (NGX) I think are 14W, and more efficient besides. You'll need to bore the top of the Mag (well, one of the tops 😉) to fit the ballast in; it's quite round, but just a hair bigger than the Mag ID.
showpost.php
You have to copy the Imageadress, and insert it between the img-tag
And sorry for infecting you by a simple photo 😀 Now i have to work on a new picture, somthing like a 4 headed, or a bended 6D like a "U", or.... or... 😛
A little thought later i have decided on 3 x MCE in one end. More power in the P7 but the 3 day old fisheye dont fit in the DX reflector.
What about the low power end, any thoughts?
Re: 2 headed M*g in progress 3 x MCE and 1 x P60 dropin
Did some thoughts and work on the battery compartment today.
One end ( high power) will deliver positive and negative to the light.
A wire vill run from the battery positive to the positive in the other end. To avoid the negative ring the wire is feed through the side.
The finished result
The negative end with a lot of springs 😀
Internally a spring to make negative contact and maintain compression on the cells.
To make the extern contact another spring to keep pressure on the contact points in the other end.
The positive was a little more complex to fabricate.
The brass thingy was made with a concave rescess to make it guide and "lock" onto the M*g contact's positive spring when the light is assembeled.
Next wil be some sort of adaptor so the low power end will accept P60 dropin's. And then fishing assembling, hopefully tomorrow.
Not really relevant to this build, but you mentioned a P60 drop-in, and I thought ''hey, a P60 would fit in a custom D tailcap, for greater stealth." Not sure about a stealthy switching arrangement, though. Maybe a twisty-tailcap? Use a wire to connect the tailspring to the - contact of the switch, and thus to the body, then the P60 in the tailcap only gets - when it's tightened. (Naturally it gets + from another wire.) At least until the type-II anodize wears out and the tailcap threads start conducting...
So the P60 mod is complete.
Funny thing the P60 spring fits nicely on the outside of the M*g bulb post.
Sorry for the ugly red but it was all i had in 2" diameter on a sunday midnight 😗 The P60 is held in place by the front lens and thereby keeps proper contact.
The beast lives
Now i have come up with a project even sillier than this and the 12 D BigM*g :crackup:
That's completely nuts.... I love it!
