Thanks - let's go from there.
Assuming
White LEDs
- 3 x single die, power LEDs like a K2 TFFC or Cree equivalent. (Cree is fine, I just know the Lumileds products better so I will use them in the example)
- Capable of substantial output from 1,000 ma - 1,500, sometimes pushed harder
- Vf approx 3.5 - 4 volts, depending on drive current
- The single die package will make it easier to focus for throw if you want that, or defocus for more of a flood beam.
Red LED
- Lux III Red or red orange
- Capable of substantial output from 500 - 1,500 ma
- I have a light with this in red/orange, set at 1,000 ma, and it will shine right through your eyelids, but remarkably, still preserve some night vision.
- Vf approx. 2.2 - 3 volts, depending on drive current
2 or 3 cell NiMH C of D cells
- Drive the 3 white LEDs in series with a boost driver at 1,000ma or so. Hook this up to one on/off switch.
- Run the red LED either in direct drive mode (2 cells) or with a 2 ohm resistor (3 cells) with its own switch. I know this is not optimum, but it actually will be pretty efficient. It is easy to bench test this setup and determine if you are happy with it before building up the light.
It might be possible to find a double pole switch that will throw both circuits at the same time. (one off, one on)
On my home built light called "Breeze", I set it up pretty much just like this except for one white LED and one (small) red LED. There were some difference though, so the switch I used will not work for you.
