Hey all give me some insight.
I will be running 12 k2 leds in 2 seperate housings. So 6 in each. I plan on using the cchipo driver from task led to run all of the leds.
What do you all think is best for my application. to run them all in series or possible a series parallel combination.
Here are the specifics to the driver if you are not familiar.
CCHIPO - Constant Current High Power driver
V1.2 now available and shipping (1 May 2008)
1) Maximum output voltage raised to 48V (previously 39V).
- Boost converter (4V - 30V input). Maximum 5A input current.
- Fully current regulated.
- Adjustable current limit via onboard precision 25 turn trimpot.
- Connections for optional external Potentiometer.
- Output voltage up to 48V.
- Maximum power output 45W.
- Open circuit protection (maximum 48V output).
- >85% efficiency.
- Board is 2.5" x 1.9". Maximum height at heatsink is 1.65".
