Icebreak
My apologies if this one has already been discussed.
I bought the (New?) 2005 Coleman 8D Pack Away Spiral Fluorescent Lantern on Wednesday at Wal-Mart for $19.79.
8D Pack Away at ColemanDotCom
This picture is a little wrong. The square lens is totally clear all the way around.
I haven't field-tested it so I won't recommend it yet. I have a couple of concerns. This lantern collapses into itself. I haven't looked to see how they engineered the locking mechanisms. I wonder how durable they are. Your fingers don't have to press anything. You just give it a jiggle and a yank then it expands and locks in the extended configuration. Give it a little shove and the illumination section slides down and locks making a compact unit that feels sturdy. I like the feel of the lantern in this position. It looks like some kind of ammo carrier in the "Pack Away" configuration.
The switching is on top. I wonder if that is such a good idea for rainy weather. I suppose one could easily protect the switch.
The batteries load very easily from the bottom. They do rattle but that's of no concern to me.
I was really surprised with how bright it was when I turned it on. It's somewhat painful to look directly at the lit spiral. From reading about fluorescent lights on this forum I would attribute the brightness to the compactness of the 15W spiral tube. Also, see that reflector? It really works very well. A lot of light is reflected upward and outward. See the hole in the reflector? That's to allow the spiral tube to enter the power section when collapsing the lantern. Pretty slick.
With 8 D primary cells in it the lantern is heavy. One advantage might be that it could probably endure 35 - 40 mph winds without tipping over. I guess if I wanted it to be lighter I could make an investment in some rechargeable D cells.
I'm thinking that this will be a good power outage light. Set on a coffee table it throws light all over the living room. There is a 4'x4' dark spot (not really a shadow) on the ceiling. While I'm sitting in a comfortable chair 8' away from it there is more than enough light to read by. I don't know about that 26 hour claim but I think 18 hrs. would be reasonable.
For $20.00, I thought this light was preliminarily good enough and interesting enough to say something about it.
- Jeff
- Jeff
