liveforphysics
- Joined
- Dec 4, 2006
- Messages
- 343
Hi guys, I know I haven't been around for a long time, but I decided some of you might like to see a project I made a while ago.
It's also good to see that my "Ellaser" idea is still getting used.
So, to get started, I wanted a powerful laser with me everywhere I went, but I didn't like lugging one with me. I first made a single RCR2 powered 200mW red laser that was about 2" in total legnth. It was an interesting novelty, and the beam was mildly visible in the night sky, but I missed the visibility of the green laser for long range pointing purposes.
So, I remembered that i had purchased 10 of the deal extreme "200mW" lasers, and 8 of them were still just sitting in my flashlight stuff box. I loaded them all with new lithium primary cells. One of the lasers had a clear cut brightness advantage over the others. I decided to use this one for my project.
Looking at the size of the pen style pointer, I knew what a bulky item it was to carry. Also fairly heavy for a pen style pointer.
I first thought I would need to somehow shoehorn the guts from this pointer into something like a single AA cell flashlight housing powered by a single half AA cell. I know this would be possible, but it would also take at least more than a few hours, and I didn't want to spend that much time.
So, I decided to see how the laser performs when powered by a single 10440 Li-ion cell. Well, I gotta say it does awsome! Compaired with 2 new lithium primary cells, the laser is signifigantly brighter! The driver board also gets warm/hot very quickly.
So, to cut to the chase, I shortened the package of the laser as small as I could go, heat sinked the driver board to the brass tube wall with thermal epoxy, thermal epoxy'd the LD back plate to the LD houseing, and thermal epoxy'd the laser houseing to the inside of the brass tube once I had everything worked out just how I wanted it.
I did this about 3-4 months ago, and aside from scratches and nicks that I really don't care about, its been a handy tool that hardly is noticed in my pocket. It's also been cheaper to feed with the rechargable 10440 cells vs buying bulk packs of lithium primarys.
The little red rubber cap is my favorite part! The electrical tape around the tip is to ensure the cap has a tight fit. The cap works as a saftey to prevent the beam from hitting something I don't want it to if the button is accidentally pressed, AND the button keeps the dust and pocket lint off the lens. I also ground the switch button down to be slightly under flush with the wall of the case to avoid accidental button triggering when it jingles around in my pocket.
It's brought laser convience to a whole higher level for me. The laser beam is brighter than other lasers I've bought for 4 times the price that never get used because they are not handy to carry or use due to size and goofy switching functions.
Cost of mods:
Artic Silver epoxy and a 10440 (both items i have loads of laying around) $10
Time to mod: About 1.5 hours for the first time, I could do it in half the time now that I figured out what to do.
Here are the pics.
And of course a beam shot pic. You can see it has a little bit of dust or something on the lens when I took this picture. Foruntately with the exposed front, cleaning is a snap!
Cost of mods:
Here are the pics.
