One of my low beams on this truck went out. I wish for better lighting since I am in the northwest with lots of animals on the road. I read the sticky about not upgrading to LED or other major mods and also it seems sticking with the OEM bulb is generally the better way to go. I'm not interested in doing anything extreme in terms of modifications or wiring. From what I can tell, lows are H11 or H1155 (not sure what the 55 indicates) and highs are 9005. I do tow a travel trailer periodically also. Short of investing in a new vehicle with theoretically improved lights, here are my questions. I'm willing to spend extra for improved seeability (I just made that up).
Is it best to stick with the OEM bulb? Do lights start to fade and if I buy new OEM bulbs, will the resultant light be better than I'm experiencing? I find it helpful to use the fog lamps on this truck to light up the sides but of course I forget to use them at times.
Second, if I upgrade, I found recommendations to H11 upgrade for Phillips X-treme Vision or GE Lighting Nighthawk. Is this still accurate for better light? I saw a reference to reduced lifespan with these; could someone elaborate?
Third, I see references to an H9 upgrade. Is there a learned opinion on this or an article I can read? If this is an option, is the result significantly better?
Fourth, should I swap the highs at the same time with a similar bulb? From what I understand (without having investigated fully), bulb swap in this vehicle is more than the usual pop the back of the housing out.
Last (for now), does the DRL feature have any bearing on my replacement choice?
Very last: thoughts on the fog/auxiliary lights? 5202 bulbs I think.
Very very last: anything else I should consider?
Thanks in advance for your learned wisdom and help.
Nate
Nate
