2011 Flashlights from Peak LED Solutions
Curt R
. 2011 LED Flashlights From Peak LED solutions
From
Peak LED Solutions
The following is a list of the Peak LED Solutions flashlights that we are offering for 2011. Most have many options such as different battery compartments, different base materials and different power output levels. Some even have different output beam patterns and LED light colors. Colors available: Blue, Red, Green, Amber and high Cree CRI white LEDs, additional charge required.
Made exclusively in Phoenix, Arizona USA
Pocket Lights: Single output level only
Matterhorn: AAA battery three 5 mm UV or IR LEDs only
Kilimanjaro: AA battery seven 5 mm UV or IR LEDs only
McKinley: CR123A battery seven 5 mm UV or IR LEDs only
Pocket Lights: QTC adjustable light output
Eiger: AAA battery, Cree XPG-R5 LED, XPE all colors
Shasta: N cell or AAA battery, Cree XPG-R5 LED, XPE all colors
El Capitan: AA battery, Cree XPG-R5 LED, XPE all colors
Volcan: AAA or AA or CR2 battery, Cree XPG-R5 LED, XPE all colors
Logan: CR123A or RCR123A, battery Cree XPG-R5 LED, XPE all colors
Optional 17500 battery compartment
Pocket Lights: One inch diameter heads, QTC adjustable output
Pamir: CR123A or RCR123A battery, Cree XPG-R5 LED, XPE all colors
Sierra Madre: CR123A or RCR123A battery, Cree XML-T6 LED
Caraballo: CR123A or RCR123A battery, Cree XML-T6 LED, direct drive
Rainier: CR123A or RCR123A battery, Seoul P7 LED, direct drive
18350 and optional 18500 battery compartment
Pyrenees: CR123A or RCR123A battery, Cree XPG-R5 LED, XPE all colors
Ural: CR123A or RCR123A battery, Cree XML-T6 LED
K2: CR123A or RCR123A battery, Seoul P7 LED
Everest: CR123A or RCR123A battery, Seoul P7 LED, direct drive
Law Enforcement Lights:
Battery compartments:
Compact; 1 x 17670, 1 x 18650, 2 x CR123A, 2 x RCR123A, 2 x 18350
Combat; 2 x AA, 1 x 17670, 1 x 18650, 2 x CR123A, 2 x RCR123A, 2 x 18350
Medium; 2 x 18500, 3 x CR123A, 3 x RCR123A, 3 x 18350
Large; 2 x 17670, 2 x 18650, 4 x CR123A, 4 x RCR123A, 4 x 18350
Any listed battery compartments will work with any on the Night Patrol or First
Responder heads and with the SR450A and SR800A and SR1200A heads.
Night Patrol Series:
NP300S: Single output Cree XPG-R5 LED
NP300A: Adjustable output Cree XPG-R5 LED
NP400S: Single output Seoul P7 LED
NP400A: Adjustable output Seoul P7 LED
NP600S: Single output Cree XML-T6 LED
NP600A: Adjustable output Cree XML-T6 LED
First Responder Series:
FR400S: Single output Cree XPG-R5 LED
FR400A: Adjustable output Cree XPG-R5 LED
FR600S: Single output Seoul P7 LED
FR600A: Adjustable output Seoul P7 LED
FR800S: Single output Cree XML-T6 LED
FR800A: Adjustable output Cree XML-T6 LED
FR1000S: Single output Seoul P7 LED
FR1000A: Adjustable output Seoul P7 LED
FR 1200A: Adjustable output Luminus SST-50 LED
Search and Rescue Series:
SR450A: Adjustable output Cree XPG-R5 LED
SR800A: Adjustable output Cree XML-T6 LED
SR1200A: Adjustable output Luminus SST-50 LED
The SR1500A, SR2000A and SR6000A flashlights use
2 x 38120 rechargeable Lithium-Ion batteries or
4 x D cell Alkaline, Lithium or NiMh batteries.
SR1500A: Adjustable output Luminus SST-50 LED
SR2000A: Adjustable output Luminus SST-90 LED
SR3000A: Adjustable output Luminus SST-90 LED
Fall of 2011
SR6000A: Adjustable output Luminus CSM-360 LED
Spring 2012
Why choose Peak LED Solutions flashlights:
Standard Features:
· All Peak flashlights are Designed, Manufactured and Assembled in Phoenix, Arizona USA
· We use only the latest and highest performance LEDs available
· Most pocket lights can be ordered with colored LEDs
· Cree XP-E LED colors: Red, Blue, Green, Amber
· Electronics are exclusively potted in thermal epoxy for reliability and shock resistance
· Heads are completely sealed in epoxy
· Machined from aircraft grade Aluminum or solid Brass or non magnetic Stainless Steel
· Aluminum flashlights are black Mil-Spec Type III Hard Anodized
· Electronics are over designed and use only quality proven components
· All electronic parts and LEDs are purchased from domestic suppliers
· O-Ring seals at all openings for water resistance
· All flashlights can be provided with variable light outputs
· Protective windows are unbreakable abrasion resistant polycarbonate
· Positive battery contacts are solid brass
· Engineered to use different battery chemistries
· Different styles of battery compartments
· Choice of flashlight materials
· Mix and match heads and bodies for custom applications
· Simple twist on/ twist off
· Reliable tail switches
Peak LED flashlights have been specifically designed to the Mission Critical requirements of the Military, the LAW Enforcement community and the professional. (These are not consumer grade lights masquerading as duty quality lights). Peak LED Solutions flashlights survive where others fail. Built to thrive under the most severe conditions and get the job done. Our LED flashlights will withstand the rugged conditions of field deployment. We build in quality that will take you through the most demanding of environments.
Using the latest in electronics and LEDs, Peak lights are always at the leading edge of technology. We automatically upgrade our lights to insure that Peak lights are unmatched in light output. All Peak lights are designed to use the latest rechargeable Lithium-Ion batteries for cost savings, as well as regular Lithium or Alkaline batteries.
Because of the ultra high output of Peak flashlights, they are not recommended for use by children or non professionals. Eye damage could result. At full power and extended run times the outside of the head and case can get hot.
We take personal pride in manufacturing the best LED flashlights in the world.
Peak LED Solutions LED flashlights are designed, manufactured and assembled in Phoenix, Arizona USA by a company established in June of 1975. We do not just assemble or bring in parts or rely on outside vendors to manufacture Peak flashlights. We do not use any electronic component or part that we cannot trust. This ensures performance and reliability unequaled by any other U.S. made flashlight company.
[email protected] or 1-877-881-7325 fax 1-623-582-0526
[email protected]
Mail address: Peak LED Solutions
29834 N. Cave Creek Rd Ste # 118-249
Cave Creek, Arizona 85331
Thank You: Robyn Seabert
President - Peak LED Solutions
The following is a list of the Peak LED Solutions flashlights that we will be offering for 2011... Curt
Wow, quite a lineup! I am looking for a small XM-L light that's driven reasonably hard. It sounds like the Caraballo and Ural both fit that description. They are both rated 400 lumens. The Caraballo is direct drive (I like), but it sounds like only the Ural can take 18350 and 18500 (I like). How would you compare their output?
Did I miss something Curt? no 2 X AA brass Pamir listed, I love mine I'm sure it'll be passed down as a family heirloom, definitely feels indestructible.
Doesn't the Compact; 1 x 17670, 1 x 18650, 2 x CR123A, 2 x RCR123A, 2 x 18350 battery tube accommodate 2 X AA as well or do I have a different tube on my First Responder?
Norm
Hey curt i was wondering would you ever make a First Responder like the old one using three Seoul P4 but with XPG-R5's ?
Norm:
We have 2 x AA battery compartments that fit the Logan and 1 inch
heads that use the 16 and 17 mm dia batteries. The compact battery
compartment is not long enough for 2 x AA batteries.
276:
We could do a three head FR using the Cree XPG LEDs, but the electronics
for that configuration will only output 700 mA to the LEDs. That is 260
Lumens per LED, or a total of 780 Lumens bare bulb. The XML version,
(FR800), drives the LED at 3.4 Amps. No advantage.
Curt
These two looked interesting but I guess they never came to be
