2018 Successor to TK75nvQ?
A
ateupwithgolf
Arkansas, USA
Sorry if posting a new thread here is taboo, but I've been real happy with the TK75vnQ that I got a couple years ago, and wanted to know the latest and greatest searchlight with the same form factor of the TK75vnQ and cost <$400.
Also, is there a spreadsheet that lists all of Vinhs lights with their specs, LED, lumens, k lux, etc all in one place? Thanks!
ven
ven
Manchester UK
There is the 2018 tk75vn option, several LED flavours to choose. If you like cool white, then the sst40 option may be the one! Other than that, prob best to check through skylumen site and have a look at what will suit you best. Could always jump up a size and go the rc40vn route , or x65vn. The acebeam x80vn is more compact, but more floody..........again depends on really what your preferences would be(throw, flood or a bit of both). Now with these crazy high output lights, they reach out far enough to surpass some throwers.
L
LichtAn!
Hessen, Germany
How do SST40s compare with XHP35 and XHP70 in terms of throw and lumen? I wonder if there's a database or table comparing the most interesting LEDs for flashlights with die size, max current, etc.
Newlumen
Newlumen
United States
Right now, tk75vnq and thrunite tn40svn are the top high output thrower.
tk75vnq. Sst40/xhp35
compact.. lights are expensive from factory
great quality.
can add extended battery
thrunite tn40svn xhp 35
super bright in lumen and max lux
little bigger than fenix
great price.
L
LichtAn!
Hessen, Germany
Just did a quick research. SST-40 has more Lux than XHP35 but slightly less output right? Can't a TN40 be made with SST-40s? Wonder what are the expected numbers on a TK75 SST-40?
A
ateupwithgolf
Arkansas, USA
I didn't consider swapping the LED in my TK75vnQ. I can't remember what LED is in it to be honest. I would want a neutral white for sure, and of course more lumens and throw and I'd sacrifice runtime if another LED would fit that criteria and not off the wall expensive to swap.
ven
ven
Manchester UK
I am a fan of the xhp35 HI 5000k, so i would pick that over more output(or even more throw) as i like a neutral beam. Choices out of sst40 and xhp35 HI would depend on what is more important. Highest output, prefer cool (sst40 only has cool option for now) to neutral(cool option as well with xhp35 HI ) . Vinhs measurements are comparative, so look at both and see what best for your application:cool: in mind for the tk75vn
Newlumen
Newlumen
United States
Here are the lumen and lux..
Fenix tk75vn. Sst40 dedome. 7500 lumen and 420k lux
fenix tk75vn. Xhp 35. 7500 / 400k lux
fenix tk75vn . Xml2 dedome. 5000 / 366k lux
thrunite tn40svn. Xhp 35. 9000 lumen and 500k lux
A
ateupwithgolf
Arkansas, USA
Thank you very much for this info!
Newlumen
Newlumen
United States
Your welcome.. in my opinion, xhp 35 are durable. Led can take mass heat.. tn40svn is the best bet..,
A
ateupwithgolf
Arkansas, USA
I agree, time to pony up some more $$. It's just $$, I can't take it with me.
A
ateupwithgolf
Arkansas, USA
Can someone tell me the recommended 18650 batteries for the tn40svn? I know they need to be protected is all I know. Thanks.
Newlumen
Newlumen
United States
I believe you can use Sony vtc5, vtc5a, VTC6, or Samsung 30q.. all unprotected.. not sure if it required button top. Will have to check it when I get home.
A
ateupwithgolf
Arkansas, USA
I was just going by website description for tn40svn at skylumen that says "4 protected batteries needed." Is that a misprint?
Newlumen
Newlumen
United States
He didn’t mention using protected cells when I bought it. So I use Sony VTC6 flat top on my tn40vn. You will need to ask Vinh about that.. or mod to take unprotected cells.
J
jo_th
Hows the tn40svn now using unprotected cells, still working fine?
L
LichtAn!
Hessen, Germany
I talked to Vinh about battery choice when I bought mine. He doesn't recommend using unprotected high current cells. It's a gamble because the TN40vn draws an enormous amount of current for the XHP35s and depending on the individual emitter, you might kill one. I charge my VTC6s to only 4.1V when i use them in the TN40vn just to be safe.
J
jo_th
Ah then your losing potential extra runtime, if high Amp cells is the problem I wonder if unprotected sanyo GAs will work fine?
L
LichtAn!
Hessen, Germany
Nah you are not really losing anything, because the GAs will have a higher voltage sag under such heavy loads. So in the end the VTC6 even at 4.1V will probably last longer until 3V than the GA would. Of course you can safely use the VTC6 at anything below 100% at 4.2V
Similar threads
vinhnguyen54
  • Locked
75 76 77
Replies
2K
Views
198K
cclight
C
vinhnguyen54
Replies
Views
69
vinhnguyen54
vinhnguyen54
vinhnguyen54
Replies
164
Views
35K
jo_th
J
vinhnguyen54
Replies
18
Views
4K
vinhnguyen54
vinhnguyen54
