BVH
The latest info on AAC's website indicates replacement battery packs for the 24 Watt flashlight are 4400 mah in capacity. I assume our original AC version battery packs are supposed to be the same? The label on mine says never to charge more than 2200 mah.
I ran my light until it quit. I then made a charging pin adapter so I could charge the battery using my Schulze charger.
I'm going to make an assumption that 24 Watts are provided to the bulb. Given the typical ballast efficiency of 75% to 80%, I'm going to say that total consumption is 29 Watts or 80% efficiency.
The pack uses 3 Li Ion cells at 3.7 nominal volts each for a total nominal voltage of 11.1. Based on this, amperage draw should be in the neighborhood of 2.6 Amps. 29 Watts / 11.1 Volts = 2.6 Amps.
So I hooked up the charger, set it to charge at 1.2 AH - the rating of the 120 Volt charger wall wart and to discharge at what I thought the light actually discharges at while running - 2.5 Amps and let her go. (I could not set 2.6 Amps) Here are the results:
...........................................charge.........discharge.....run time(discharge time)
Charge/Discharge cycle #1 - 1655 mah.......1620 mah........39' 10"
Cycle #2..........................- 1720 mah.......1660 mah.........40' 25"
Cycle #3..........................- 1660 mah.......1665 mah.........38' 57"
My light always runs for between 38.5 and 39.5 minutes without fail so I believe the 2.5 Amp discharge rate is right-on.
I would say the battery's capacity is closer to 1650 mah. If the battery were, in fact, 4400 mah, the light would probably run the 110 minutes that is stated on the website.
My Shulze always charges 3-cell Li Ion packs to 12.6 to 12.66 Volts. It would not charge this pack beyond 12.53 Volts.
Despite the short run time, I really like this light. It fits my hand well, stores in my truck in its small case and puts out a tremendous amount of 4300K light for a 24 Watt'r Mag style light.
