2AA to 2D adapter
Lynx_Arc
Tulsa,OK
As it is with resistors in parallel the lower resistance path will be taken more often. So battery discharge will differ unless you match the cells well. The advantage is that as a bettery is drained down a little more then the others have a higher voltage and get drained also. Unless you have a battery that as it discharges the internal resistance lowers it shouldn't be a problem.
MrTwoTone
ohio
Yes there is a AA to C,MCM stocks them also.I can get their stock # on Monday if you want.
