Sold/Expired <<< 2ND RUN >>> SF M6 Short Tail-Cup + 6x17500/AA Carrier
petrev
SW England
<<< CLOSED >>> SF M6 Short Tail-Cup + 6x17500/AA Carrier
Hi
SALES OPEN
Short Tail-Cup - Now In Stock - No List - Just Buy Now
Carrier Interest List1 Closed - Carriers - Do not Pay if not on List
Carrier 2nd. Run List - Closed -
SF M6 Short Tail-Cup Accessory - In Stock
Special Carrier is 6 Cell and available assembled for . . .
2s3p for Lithium 17500
6s for Lithium 17500 or NiMH AA
6s NiMh is an alternative for 5xXRE MZep mod and MN21 etc.(not tested by me)
Price Update - 2nd. RUN
STC $25
(Worldwide +$4 :for AirMail(from 5Days), PPFees, and Packing)
(UK £18.00 inc.1st Class)
extra tailcups plus $1.25 per tailcup PPF
Carrier $50 (old$40)
(Worldwide +$6 :for AirMail(from 5Days), PPFees, and Packing)
(UK £38.00 inc.1st Class)
extra carrier plus $3 per carrier PPF, P and P
KIT
STC +Carrier $70 (old$60)
(UK £52.00 inc.1st Class) (old£44)
extras as above
Worldwide Signed-For AirMail with tracking Add Extra +$5.50
Worldwide AirSure (from 4Days) Add Extra +$6.60
Interest List2 Open -
PayPal
cpf(at)xuum.com
Post Here and
PP Note - Include exact details of order
Please state Type and Usage
Type: 6S or 2S3P
AW17500 or AA (or ? ? ? ?)
Led Zep Mod or Std. SF-MNxx type Incan - spring base lamp (or ? ? ? ?)
eg.
1x KIT STC +Carrier (Type:6S AW+LedZep)(Type:2S3P AA+MNxx) $70
1x STC $25
+$1.25 per tailcup PPF
Total = $102.25
CPF = !Handle!
PM any questions ? ? ?
Used for :-
2x C-Lion
6x 17500 M-Zep or 5761(2s3p)
6x AA NiMh
6s or 2s3p Carrier Versions
6x 17500 PhD ? ? ?
2x C-Lion
M-Zep module chart for Carrier + STC
:candle:
Short part in the middle, with a late model M6 cup on top and a very old M6 tailcup on the bottom:
Will
I had some made before for that illfated HDM6 project
This Short Tail-Cup can be used with my 6x17500 carrier for M-Zep mods and the carrier and cup design could also be used with a version of the PhD-M6 (programable hotwire driver for the SF-M6)
6x17500 Carrier
The PhD-M6 would have to be a design similar to the JS-Willie Hunt M6R LVR3i and I am not sure what stage the PhD-M6 is at exactly (must read that thread properly)
My version of the JS-M6R
Lots of ifs and buts and Qs no doubt .
Cheers
Pete
Re: <<< INTEREST ? >>> SF M6 Short Tail-Cup Accessory
Interest List 1 (Carriers - Closed)
01. :thumbsup:[01] Led Zep (STC+C[LZ-6S]) * PPP+SH12-FEB . ARR 17-FEB
02. :thumbsup: [02] william lafferty (STC+C[LZ-6S#01] +C[MN-2s3p#03]) *PPP16-FEB SH20-FEB . ARR 28-FEB
03. :scowl: [06] nailbender (STC +C[LZ-6S#05) *PPP18-FEB SH23-FEB .
04. :thumbsup:[03] easilyled (STC +C[LZ-6S#02]) PPP17-FEB SH20-FEB . ARR 21-FEB
05. :scowl: [12] Lips (STC +C:[LZ-6S#07]) PPP21-FEB SH26-FEB .
06. :thumbsup:[11] tx101 (STC) PPP19-FEB SH20-FEB . ARR 21-FEB
07. :scowl: [12a] DaFABRICATA (STC +C:[LZ-6S#08]) PPP24-FEB SH26-FEB .
08. :scowl: [07] Edwood (STC) PPP18-FEB SH23-FEB .
09. :scowl: [08] 1rwx7 (STC +C:[LZ-6S#06]) PPP18-FEB SH23-FEB .
10. :thumbsup: [04] leukos (STC ) PPP18-FEB SH20-FEB . ARR 25-FEB
11. :thumbsup: [05] BSBG (STCx2 +C[6S-AA-MNxx#04]) PPP18-FEB SH20-FEB . ARR 27-FEB
12. :scowl: [09] kansasfarmer (STC) PPP19-FEB SH23-FEB .
12A. :scowl: [10] mudman cj (STC) PPP19-FEB SH23-FEB .
14. :scowl: [14] snakeeaterhg (STC +C[LZ-6S#09]) SH27-FEB .
2ND RUN Carrier List :tinfoil:
.201. [P201] bigchelis (STC+C[LZ-2s3p AW17500]) SH08-MAY .
.202. [P202] JustinCase (STC +C [LZ-6S AW17500]) Ready . . .
Pete, any chance you could offer the 6X17500 carrier as well?
I'd be interested in the set.
Pete,
I'm not sure if your particular model of tail-cup will work or not, you may want to confirm, but....
I've been using a version very very similar to yours that when used with a PVC pipe spacer, can allow the user to use 2xAW LiON "C" cells. This has been my means of using a rechargeable setup in the Surefire M6 as well as a few modded lights.
If yours can use the 2xC cells I'm sure others may be interested in addition to the battery configurations listed above. ;)
Thanks for offering these.
MSax
Hi Pete
I would also be interested in the carrier and the shorter tail cap as I also have fallen for the LZ mods
thanks
Dave
Thanks all
Noted interests
I shall have to find a way to make the carriers in a less time consuming way ! ? !
MSaxatilus
Yes 2xC-Lion (method HERE) is perfect with the Short TailCup - I had been using just that setup before falling to the power of the M-Zep.
Thanks for the reminder.
Cheers
Pete
Thanks all
Noted interests
Cheers
Pete
Pete, just charge accordingly, I'm still interested.
MSaxatilus
:thumbsup:
Re: <<< INTEREST ? >>> SF M6 Short Tail-Cup for 2x C-Lion and 6x17500
Hi
Update on how to use a 6x17500 carrier with the standard M-Zep modules
:candle:
Pete
I'm interested in theory.
However I have zero modding skills. In fact I destroy everything I try to fix. :laughing:
So, my interest is dependent upon the removal of the existing tailcap
and replacing it with the short tailcap being completely easy and foolproof
AND the 6x17500 slotting in with no adjustments necessary and again being easy and foolproof.
If any degree of intelligence or skill is involved in replacing my existing set-up, then I shall leave well alone.
To run my M6 with 2xAW LiON "C" cells
count me in
I'm interested in one as well.
-Ed
Hi easilyled
Should be straightforward ! ! !
You can see if part of the process is possible by practising part 1. SF-Std.TailCup removal.
1. Pull SF-TC
Grip central spring pillar using finger and thumb or pair of pliers if needed. Pull - Cup should release fairly easily. Use a cloth if you wish to avoid any marks using pliers. May need small wiggleing motion !
2. Replace - pretending this is the new STC
:thumbsup:
The Carrier is simply loaded with 6 cells - 3 stacks of 2 cells - each stack is placed in NEG end first - NEG towards the spring. One stack is reversed in orientation still with the NEG to the spring.
POS end of carrier goes in first as with std. cells and FM carrier. POS end has a spring as standard.
Cells do tend to try to spring out of carrier at any possible moment so the carrier has to be loaded and gripped as it is fitted ! ! !
I have managed all this and don't feel it is beyond most - but I will try to get a photo description together soon to help . . . and if you or anyone feels this is all too much I understand.
Does this all make sense ? ? ?
Any questions ? Just ask.
easilyled STC +C
Lips STC +C
tx101 STC
DaFABRICATA STC +C
Edwood STC
Interests added
any changes/errors please let me know
Pete
Thanks for the detailed explanation.
It doesn't sound too daunting even for me. :)
Hi
I make it sound easy :thinking:
As you are in the UK I can always fit the STC for you if you find any problems and check it all works if needed . . . postage isn't too much inside UK.
Cheers
Pete
I'm interested in a cup and a carrier. I have the 3XP7 sink on order:devil:
Any guess on the cost of the carrier?
Thanks,
