Sold/Expired 2x32650 3x32650 M body by Fivemega
fivemega
California
(AVAILABLE)
Please allow 7 days to ship
Here I have very limited quantity of these M bodies which is made from 3 major parts.
1- Neck is a copy of $urefire M head which can be screwed on body barrel.
2- barrel is D size to hold batteries and bored out to 35.3mm to accept bundle of 4AA. Outside is also grooved for better grip.
3- Tail cap is grey version of these and can be tail stand.
Combination of above parts will make complete body and tail cap of M series which come with installed McClicky switch and all necessary orings, all in mil spec natural hard anodized.
Inside barrel diameter is about 35.3mm and different total battery length which is stated next to each body.
You can install your batteries of 26600, 26650, 32600, 32650 or any battery pack of AAs
It is obvious that some spacer (PVC tube) needed for 26mm diameter batteries.
Please measure total length of batteries to make sure will fit.
Shorter batteries may need some magnets for proper connection but switch spring will compensate slight length.
It is also possible to use your battery pack of 8AA or 12AA
These will open more opportunity to use your M6, M4, M3T, M3 and all aftermarket M head using proper voltage lamp assembly or LEDs weather you need more voltage or more run time.
Please note that head, lamp assembly and batteries are not included or sold here
You must add a note to your paypal for item size/number, your CPF handle and make sure for an accurate shipping address.
Price: $79 each unit.
Shipping to all States $9
International shipping $18
Insurance to all States $6.20 for each $100 value
Insurance Internationally $8.80 for each $100 value
Please pay first, then claim the next available size and number.
Paypal:[/COLOR] [email protected]
These will take batteries of 35mm diameter and total length of 127mm
#01 M Body 2x32600 (35x127mm) $79 (AVAILABLE)
#02 M Body 2x32600 (35x127mm) $79 (AVAILABLE)
These will take batteries of 35mm diameter and total length of 137mm
[SIZE=-2]#01 M Body 2x32650 (35x137mm) $79 foxtrot824 paid shipped 9505513808437026049898 [/SIZE]
#02 M Body 2x32650 (35x137mm) $79 (AVAILABLE)
#03 M Body 2x32650 (35x137mm) $79 (AVAILABLE)
#04 M Body 2x32650 (35x137mm) $79 (AVAILABLE)
#05 M Body 2x32650 (35x137mm) $79 (AVAILABLE)
These will take batteries of 35mm diameter and total length of 141mm
#01 M Body 2x32700 (35x141mm) $79 Steve in SoCal paid shipped 9114999944238373526453
#02 M Body 2x32700 (35x141mm) $79 skillet paid shipped 9500113808439073212529
#03 M Body 2x32700 (35x141mm) $79 (AVAILABLE)
#04 M Body 2x32700 (35x141mm) $79 (AVAILABLE)
#05 M Body 2x32700 (35x141mm) $79 (AVAILABLE)
These will take batteries of 35mm diameter and total length of 206mm
#01 M Body 3x32650 (35x206mm) $79 Genna paid shipped LC550703796US
#02 M Body 3x32650 (35x206mm) $79 DayofReckoning paid shipped 9500113808430185314651 [/SIZE]
#03 M Body 3x32650 (35x206mm) $79 (AVAILABLE)
#04 M Body 3x32650 (35x206mm) $79 (AVAILABLE)
(A V A I L A B L E)
fivemega
California
***QUESTIONS???***
Do you think a MN20 or MN21 in a KT4 will survive the power from 2 x 32650?
I have tested MN21 in KT4 using 2 IMR 26650 and MN10 in Z46 using 2 protected 26650 and love them.
Awesome stuff.
I am a bit ignorant of what 32650 to buy and how best to charge? Any suggestions
Charging a 32650 is easy and not a problem when using these or similar methods.
There are also chargers that can hold a 32650
Google search is best way to find quality 32650 battery and charger.
Would it be possible to use a Philips 5761 inside one of your Bi-pin Socket for MN Lamp Assembly adapters?
What I mean is, using two LiCo or LiFe cells, which head would I need?
I would love to use a Surefire MN11 but they are too expensive to risk "poof" off 2x32650 LiCo cells.
However, Philips 5761 is cheap and should run okay with two 32650 LiFe cells.
3) Would a regular M3 head, part Z46, work?
Or, would I need a "turbo head", part Surefire KT4, to fit...?
MN10 and MN11 fit Z46 head.
MN15, MN16, MN20, MN21, MN60, MN61 and MN bi-pin sockets will fit KT4
MN11 runs very hard using healthy and fully charged pair of li-ion. So no guarantee to survive or instaflash.
It depends on total resistance of system. battery health and charger ending point.
Some people are happily use them for a while but others upset of instaflashing.
For safer run, pair of LiFePO4 is recommended when using MN11 but If you have possibility of using MN socket, then WA1111 with KT4 and pair of li-ion 32650 is safer and brighter.
Above statement is for incandescent bulbs only. Please check total acceptable voltage of your LED lamp module.
I like a wall of light with a large, floody center.
Will the Philips 7388 be floody, throwy, or in the middle in KT4 head...?
First thing I would check is diameter of bulb envelope to make sure will fit inside reflector opening.
Sorry, I don't have 7388 to test.
http://www.candlepowerforums.com/vb...2x32650-3x32650-M-body-by-Fivemega&highlight=
FiveMega, can the tailcap on these be easily disassembled and the McClicky replaced if necessary?
Yes, very easy.
Just remove rubber from back side of cap then using tiny neede nose pliers remove McClicky switch.
Steve in SoCal
Awesome stuff.
LEDAdd1ct
Hudson Valley
1) The Xtar VP2 can charge one single 32650 at a time:
Link One
Link Two
2) @fivemega:
I know they are discontinued and that I would have to post a wanted ad.
What do you think?
fivemega
California
What do you think?
It depends on total resistance of system, battery health and charger ending point.
LEDAdd1ct
Hudson Valley
Okay, thank you for your reply here and your email as well.
Thank you!
fivemega
California
Steve in SoCal
I will take and paypal sent for
#01 M Body 2x32700 (35x141mm) $79 (AVAILABLE) -20%: $63.20
$7 shipping
Total :$70.20
Thanks
fivemega
California
Steve in SoCal, your payment received and order shipped and tracking number is added on post #1
More 2x32650 3x32650 M bodies available.
Please check post #1 for next available size and number.
Steve in SoCal
Thanks FM. I'm happy to be the first one to buy this cool product. Will post some pics when the body arrives.
foxtrot824
The 02135!
I'll take it!
#01 M Body 2x32650 (35x137mm) $79 (AVAILABLE)
PP sent! $79 for body plus $7 shipping US, $86 total.
