Hi folks,
This in not a INTEREST, PRE PAYMENT or RESERVATION thread.,
This is an introducing thread for already existing item which will be available soon.
These are FM3X and FM3-3 which is modified to fit Megalennium and M6 body and comes with an adapter for head and another adapter to fit reflector instead of cam. All heads are HA to match closely to origial M6 bodies.
This is a 20 seconds simple modification and does not need any skill or tool.
Simply remove existing head of your Megalennium, M6, M4 and M3T and install this 3" turbo head instead with proper lamp assembly such as MN socket, MN20/21, MN60/61 or any other aftermarket. NO LAMP ASSEMBLY OR SOCKET INCLUDED.
Since bulb opening of these reflectors are 12.7mm, you can use other larger G4 bulbs that won't fit in $urefire reflector.
Price will be same as FM3X ($190) and FM3-3 ($193) for Megalennium original owners in this list and $20 more for others.
You can also buy adapters set for $30 (including one M to D adapter and one for FM reflector adapter) to use with your M*g D head.
Again, this is only introducing thread.
Please do not pay.
Any comment welcome.
