Someone suggested doing a comparison of some of some of the rechargeable 123 cells currently on the market. I've just received a couple different types of these cells, so I thought I'd do a "quick and dirty" test of the ones I've got and post the results. It's not fancy, but I think it should reflect relative real world results. It will have to do until someone does a more controlled test.
Batteries:
BatteryStation.com RCR 123A- protected, "700 mAh"
JSBurlys.com Rechargeable 123- protected
BatterySpace.com Powerizer RCR123A- unprotected, "650 mAh"
I tested 3 of the battery station cells 2x each, and 2 of the other two cells 2x each, for a total of 14 tests.
The first test light was a regulated Longbow Micra, which pulls a nominal 1.6 Watts. The second test light was an unregulated Q3, which must have been pulling a bit less than twice that. I've averaged the Run Times:
Q3-
Battery Station: 39 minutes to cutoff
JSBurly's: 36 minutes to cutoff
Battery Space: 34 minutes* deep discharge- to about 2 volts
Longbow Micra-
Battery Station: 73 minutes to cutoff
JSBurly's: 67 minutes to cutoff
Battery Space: 63 minutes* deep discharge- to about 2 volts
So in this sample the Battery Station cells seem to have a small advantage (7% or so) over the JSB cells, with the Battery Space cells taking up the rear. Given that the battery space cells are not protected and they also give the worst run time I'd say they're clearly the losers of this test. The other two each have different advantages:
The Battery Station cells charge the fastest and have the most capacity. One of my chargers appears to show a "green light" a little early, in that it displays green at about 4.1 volts, though the voltage will continue to climb to close to 4.2 volts. You'll get shorter or longer run times than mine depending on how long after the green light comes on you pull the cells off. There is also slight variation from charger to charger- one topped off to 4.21 volts, and another to 4.18, so "your results may vary".
The Battery Station cells are slightly larger in diameter and longer than most CR123s- they will not fit into an L2, for instance.
The JSB cells will fit into an L2 or other smaller bore light. The charger makes sure every last bit of juice is in the cells before it shows a green light, topping off at 4.24 volts, and it takes much longer (hours) to charge the cells than the Battery Station. The aesthetics of the JSB cells are a bit better than the Battery Station cells.
The Battery Space cells don't seem to have too much going for them...
Hope this is useful.
Batteries:
Q3-
Longbow Micra-
