I just received my EBAY order of 12 @ 10 D-cell packs of 5 serial 3 V 7500 mAh lithium D cells * 2 parallel configured as a 15 V battery pack. I understand that these were originally built to U.S. government spec as weather baloon power sources. My cost, including shipping, was $1.025 per cell -- about the cost of an alkaline 1.5 V D cell. They are cheap because they are almost 20 years old. The vendor assures me that most of the 7500 mAh capacity remains. I wonder what the U.S. government paid for these when they were new. (The only Lithium D cells I've previously seen are ultra low current designs and cost about $20 per cell.)
The cells are welded together with both positive button and negative case strip connectors at the top of each cell. The unconnected exposed recessed bottom surfaces with a central tab look like they are live negative contacts. I won't be able to tell until tonight.
I expect that it will just take a little solder to make the cells interchangeable with regular D cells in a flashlight.
Both negative battery lead wires go from battery through diode through fuse through diode to common cathode connector that apparently are designed as a safety factor to prevent both accidental shorting and overloading.
The vendor stated that maximum recommended current was 2.0 Amps. I assumed that meant 2.0 Amps per cell, but it may mean 1.0 amps per cell given the serial / parallel pack arrangement. I'll check voltage drop under load tonight.
Brightnorm's and Mr. Bulk's group buy packs will be sent shortly.
