3 X LR44 for Wee?
munchs
The diameter and length are about the same as 10180. Has anyone ever used these stock 3XLR44 button cells in a Wee? Seems to me a good alternative when no electricity is available.
I don't know how much voltage drop you'd get under load, but you're talking about 4.5 volts vs. 3.7 nominal under load for Li ion.
That just might be enough to let the magic smoke escape.:poof:
Tim
I know that can be done with the Peak Matterhorn that uses the 10180 cell but the output is much less and the runtime is cutdown by 50% or so. The SR44 cells will provide better runtimes than the LR44's.
Tim
I'm not so knowledgeable at electronics, but won't the resistor in the LE handle it? I'm not sure though...
SR44 cells are much harder to find than LR44 cells. LR44 I found on the net has 1.5v/150mAh capacity. Won't they last longer than 10181 cells?
At 150mAh they should last longer than the 10180 cell. I doubt the ones I had where 150mAh or they where past their expiration date. I guess I'll get some new ones and try this test again.
Are those alkaline cells? If so I'm pretty sure that at the wee's consumption their capasity will slump down below 10180. That's how alkaline batteries work. But I think it is a good idea to use them in a pinch, I know that I'll do it if it comes to that.
So, anyone confirms this can work?
Rob?
I'm dying here looking at my beautiful Wee NS sitting on the table, not being able to fire it up...
not sure for your wee... but for the Orb Wee NS, it'll draw 200ma from the 10180
We know that wees use resistors rather than a circuit to compensate for the small size.
For 10180
R = V/I
R = (Vin-Vdrop)/I
R = (4.2-3.6)/0.2
R = 3
For the sake of simplicity we'll assume the SMT resistor is 3 ohms [I wouldn't be surprised if they used a 3.3 ohm resistor, as they are more common]
3xLR44 cells assuming they don't sag under load :huh:
3 = (Vin-Vdrop)/I
3 = (4.5-3.6)/I
I = (4.5-3.6)/3
I = 300ma
An XR-E s usually driven above 350ma, so your cree won't be damaged.
Theres not enough umph for the button cells to heat up the resistor nor give enough surge to last that 300ma for any longer than maybe a second.
LR44, assuming alkaline...will sag to nothing under 300ma of load:ohgeez:
I don't have a wee...but it doesn't make sense how something could fail.
Note: The capacity has nothing to do with the internal resistance. You could use four LR44s and still have less voltage under load than the 10180. in fact, certain LED keychain lights relies on the internal resistance of LR44 cells to limit fowarding current.
NOTE: To anyone trying this, you need to put tape around the batteries after holding them in a vertical stack otherwise they will short out when the metal casing of the light touches all the sides of the cells. Sorry if this is obvious but it might not be in a hurry :)
Well, 3 X LR44 will not fit.
But, 5 x 394 (SR936SW) does nicely. On a 50L pill, it will not cause problems. It's not very bright as well. Probably 20-30 odd lumens.
It will however require some sort of spacer as it will not contact. Not long enough. Wrap the batteries with tape to avoid accidental activations.
I use 2 x of the little black disk in the tail of my Eagletac T10LC2 to complete the circuit.
Run time is not very long.:broke:
