3000 Lumens with Instant On 3000 Lumens ?
kimo_james
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
___X_This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
___X_Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
___X_SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
___X_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
___X_I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
___X_I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
___X_I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
___X_Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
___X_30-50 yards/meters (I have a big backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
__X__I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
___X_Other, please specify___Instant On 3000 Lumens _________________.
____A simple on-off with only one output level is fine for me.
____X I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
__X__IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
___X_In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_____________________________________________
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
kimo_james
Think I found it :
Zebralight SC700d XHP70.2 or Lumintop GT mini Pro 3500 Lumens XHP50.2
sween1911
Pennsylvania
I'll throw a vote in for the Streamlight Protac HL 5-X. It hits all your points except size, it's a tiny bit outside your stated range.
On high, it's instant 3000 lumens. It has multiple modes, you can set it up pretty simply using their 10-tap click sequence.
kimo_james
Thank you ; I like it and am considering despite the size .
aznsx
Phoenix, AZ USA
I bought the Streamlight Stinger 2020 !
It's Perfect for my home defense flashlight needs !
Have one of those too, and IMO it's an innovative design from one end to the other - and it's innovation that really 'delivers' and works, not just innovation to be 'different'!
sween1911
Pennsylvania
Very nice! Great choice.
I think we should update the lumens numbers in our form to reflect current offerings with 1000/2000/3000+ categories :)
kimo_james
I'm thinking of getting the Protac HL 5-X also ; is that redundant ?
sween1911
Pennsylvania
Well, you're asking the wrong person on the wrong message board if you're asking me if you shouldn't get both :crackup:but to answer your question, no. I have the HL 5-X but not the Stinger to compare it with. The HL 5-X is a good addition as a rough duty high-output blaster. It will also take (4) primary CR123's in a pinch, so that's a good feature.
kimo_james
Don't need a "rough duty" light so maybe I'll look elsewhere .
I was considering the 5-X for it's higher lumens and longer throw over the Stinger 2020 .
aznsx
Phoenix, AZ USA
Well, with the 2020 you got plenty of durability with the deal, as it has a FL1 Impact Rating of 2 meters, whereas the also excellent (from what I hear) 5-X is rated at 1 - and remember that per FL1 test criteria, '2>>1x2'.
I'd kinda like to test drive a 5-X as well, and as someone already pointed out, when it comes to potentially critical equipment, basic N+1 redundancy is recommended; so even if you get a 5-X as well, no one here will give you any stick - 'redundant' or not:). You might even find that they excel in somewhat different applications, so having both could be useful anyway. Easy for me to say of course, since it's your money!
sween1911
Pennsylvania
The Streamlight HL 5X has a lot of output, but it's not tightly focused and thus doesn't "throw" like a classic HID with a deep reflector, you won't see that long range "pencil-beam" profile. It's a wall of light though, and I've hit trees at night from a couple hundred yards and it lights up the whole thing.
aznsx
Phoenix, AZ USA
I'm considering the Protac HL 5 also. Does it come with the remote switch to attach to home defense toy?
I don't believe so. SL specializes in many models of dedicated weapon-mounted lights, but in terms of 'conventional' flashlights (which can also be used hand-held) [EDIT: specifically "long gun" lights], I believe there are several models in the Protac line which are not only capable of weapon-mounted operation, but are sold with all the required 'kit' for that application. Those are the ones you'd probably be interested in. They're listed on this page:
