I have recently completed a 35W 10 Cree XR-E 2D M*g mod torch / lamp combination with a build in battery charger.
The full details can be found here http://www.forward.com.au/35WTorch_Lamp/35WTorch_Lamp.html
The features are
- 10 Cree XR-E leds, P4's ~1700 lumens
- Ultra clear lens
- Runtime as battery torch ~25mins minimum to >24hrs maximum
- Runtime as mains powered lamp unlimited.
- Built-in delta-T cut-off charger.
- Torch powered by a 6 x Eneloop AA soldered battery pack, electrically isolated while running as a mains powered lamp.
- Variable light levels in 12 logarithmic steps from 1.5% to 100% current, brightness approximately doubles each two steps.
- Momentary Full Brightness function.
- Lockout function.
- Low battery voltage cut-off.
- Zero Off Current (ZOC) micro-processor controller. Batteries are electrically isolated from the controller 20sec after the torch is turned off. This ensures the shelf life of charged torch is only limited by the low self-discharge of the Eneloop cells (approximately 85% charge remaining after 1 year).
- Internal heat pipe to transfer heat to the tail fins.
The features are
- Ultra clear lens
- Lockout function.
