The Latest Beam Shots:
Towering over Las Vegas on the North West side of town, if taking HWY 95, the highway that goes by the "Test Site" and "Area 51"; take turnoff State Road #156 up to the Local Las Vegas Area Ski Resort.
A couple days later, (with nearly a full moon again), The ski resort area was lit up by the Gorilla Searchlight.
Here are some of those results with the 100 watt HID:
:twothumbs
Mummy Mt. & Las Vegas Ski Resort tower above Las Vegas
This is how Charleston Peak and Mummy Mountain, (taller than the Cascade Range volcanoes of Oregon and Washington state), looks from my hotel room in Las Vegas. Here the mountains are about 35 miles away. This is where I first learned to ski...back in the 60's and 70's
Mummy Mt. & Las Vegas Ski Resort fifteen minutes away
This is how Mummy Mt and Las Vegas Ski Resort look from the Tonapah Highway, or about 15 minutes drive. You actually drive past Mummy Mt. to enter the Lee Canyon area and the Ski Resort.
Panoramic Shot of Mummy Mountain and Las Vegas Ski Resort
Las Vegas Ski Resort otherwise known as "Lee Canyon Ski Resort" has three chair lifts. The two main chair lifts are a each 3/4 of a mile long with the base terminal about a quarter of a mile from camera location.
Mummy Mountain couple days before Beam Shots
Mummy Mountain, 11,460 foot tall, as seen a couple days before the Beam Shots were taken. This mountain can be seen over a hundred miles away from an airplane.
Las Vegas Ski Resort in Lee Canyon
This is the Main Upper Parking Lot and Shuttle Bus turnaround. Not much by other resort standards, but in my younger years, this parking lot was a long walk to ticket counter, seemed big enough and being just a thirty minute drive from Las Vegas, is a great place to go. This is where the 36 inch Gorilla was let loose to light up the mountain sides
Here is where I learned to ski as Child
This is the Main Ticket, Bar and Grill, Rentals and Ski Lift Loading Area. Not much by other resort standards, but in my younger years, this place was intimidating, and being just a thirty minute drive from Las Vegas, is a great place to go. :thumbsup:
Beam Lights up top of Main Chair Lift
The 36 inch Gorilla lights the Main Chair Lift Top unloading terminal. The nearly full moon makes the whole mountain somewhat visible. The light beam travels about a mile to this location.
Beam Lights up top of "Extreme Vertical Drop" ski run
This little seen ski run is seen much better than in photos when the Gorilla was aimed elsewhere. This little run, lit up by the Gorilla, is a Black Diamond run for this resort, (intermediate for other ski resorts). First time I skied that run, I was terrified.
Beam Lights up Main Hiking Chute above Main Chair Lift
Here is one of the 'Slide Paths' the Las Vegas Ski Resort would like to expand the #1 Main Chair Lift to. This patch of snow is 1-1/2 mile(s) distance from the 36 inch Gorilla. The beam lights up a good Extreme out of bounds Ski Run and is a good Summer hiking area.
Avalanche path above Chair #2
Here is one of the 'Slide Paths' the Las Vegas Ski Resort would like to expand the #2 Chair Lift to. This patch of snow is 1-3/4 mile(s) distance from the 36 inch Gorilla, and is almost completely darkened by the shadow of the upper mountain ridge as seen in other photos of this location.
Gorilla Lights up Mummy Mountain, LightSward checks focusing plate
Even though it was below freezing in this photo, I was actually sweating, I am well bundled for this Beam Shot series, having been a Ski Bum for many years and skiing all the Black Diamond runs I could find. I am attempting to adjust, the beam, focus, a little better in this photo.
2 Beams compare near top of "Mummy Mountain"
The 36 inch 100 watt HID Gorilla is to the Left and the dimmer beam to the right is the 7 inch 35 watt HID Cyclops, compare near the top of Mummy Ridge. Imagine the 36 inch Gorilla with a 1,000 watt HID.
Beam Lights up Mummy Mountain, assistant moves light for me
Here the 36 inch Gorilla is aimed near the top of Mummy Mountain, over a mile beam travel distance. My assistant is keeping watch over the Gorilla, while I operate the camera.
Beam Lights up near top of "Mummy Ridge"
Here the 36 inch Gorilla is aimed at a Ridge, over a 2/3 of a mile away. This is a ridge I took many hikers on Mountain Tours several decades ago.
A thousand foot beam lights up the nearby hillside
To get an idea of how bright this beam is, I aimed it to a nearby point on the hill, about 1,300 feet away. Remember, this is only a hundred watt HID.
Beam Lights up Mummy Mountain, Assistant aims light for me.
My assistant didn't dress well for the cold and had to 'layer up' several coats and pairs of pants. It was below freezing at this time.
LightSward inspecting the 36 inch Gorilla Searchlight
Here I am checking on the 100 watt HID, 36 inch Gorilla's focus at Mummy Mountain and Ridge, over a mile away. I need to adjust the 'focus', it seems to be focused at about the half mile point here, and spreads a little, as it reaches over a mile in length to target. The light is competing with a nearly Full Moon, which helps light up the surrounding landscape.
North Mummy Mt. Ridge
Here the 36 inch Gorilla is aimed at a Ridge, over a 1/2 of a mile away. This is another ridge I took many hikers on Mountain Tours several decades ago.
Here the 36 inch Gorilla is aimed at a Ridge, over a 2/3 of a mile away. This is the ridge I took many hikers on Mountain Tours several decades ago.
Beam Lights up Lower "Mummy Ridge"
Beam lights up frozen water fall.
This frozen patch of snow and ice is sometimes a small waterfall in the Spring and early Summer. The beam travels a mile and a half, (1-1/2 miles) from Searchlight to target here.
Map of Beam Paths in Horizontal distances only
Map shows approximate horizontal distances from 36 inch Gorilla Searchlight location to various points on the surrounding mountain locations. Searchlight is at about 8,600 feet elevation and the highest point is around 11,450 feet elevation or about 2,850 foot difference. Basic Trigonometry shows the beams travel about 25 percent average farther than the indicated horizontal distances, (the farthest horizontal distance about 9,600 feet, total distance around two, (2), miles.
To get an idea of how bright this beam is, I aimed it to a nearby point on the hill, about 1,500 feet away. Remember, this is only a hundred watt HID.
:tired: :naughty:
