Here is the MH, (HID) electronic Lumatek Lighting ballast I've purchased. I paid less than the MSRP listed below. Very Fast Start-up, and bright!!!
This thing fires up the 600 watt bulb to full brightness in very little time...
very fast! I've watched this thing
fire up the regular 600 watt HID bulb in about a minute. Manufacturer claims:
Fast start-up ...It reaches full brightness in under one minute; magnetic ballasts typically take about
fifteen to twenty minutes.....
(I changed some wording in the following as indicated by
italics.)
Not just your standard eballast the new Dial-A-Watt Lumateks have advanced dimming capabilities and are able to power different wattage lamps on the same ballast making them the most versatile ballasts available. The 5th generation Lumatek ballasts produce the highest operating frequency of any eBallast on the market today and offer unmatched performance. Now you can dim your lamps which can be a great way to deal with heat issues in your
Searchlight and to help control your electricity bill. You can also use different wattage lamps by setting the dial on the ballast to the desired output power and putting in the proper wattage lamp. Note that both the input and output power of the ballast is changed when you select different settings.
For example when you set the dial to 600W on a 1000W Dial-A-Watt Lumatek the ballast performs exactly the same as a regular 600W Lumatek ballast.
This a great feature for
Advertisers that want to use a 600W MH lamp for
one Searchlight such as the Gorilla and then switch over to a 1000W HPS lamp when it's time to
go Disco.
Lumatek makes the only dual-voltage eBallast available that produces the same lamp power when used on 120V or 240V.
This is a major advantage considering that a typical dual-voltage eBallast losses as much as 15% of its output when used on 120V.
All Lumatek models are generator ready and are capable of being used on 208V three-phase power.
Lumatek has been a long standing pioneer in creating innovative lighting technologies for the Searchlight Industry.
Lumatek offers the most complete line of dimmable multi-wattage ballasts on the market.
Sold in more than 40 countries Lumatek is the world's number one selling ballast.
Lumatek 240V 1000 Watt Electronic Ballasts burned the 2 test bulbs we tried visibly brighter to the eye than a regular coil/core ballast!
Why choose a Lumatek Electronic ballast over a core-and-coil (magnetic) ballast?
- Fast start-up ...It reaches
full brightness in under one minute; magnetic ballasts typically take about twenty minutes
- Completely silent ...you have to put your ear up to the ballast before you can detect the slightest sound
- Small compact design ...600watt ballast weighs less than 4.5 kilos compared to almost 20 kilos for magnetic ballasts.
- Produce less heat
- Cut-off circuitry ...Automatic cut off when a short is detected. For ultimate safety.
- Longer bulb life...Lumen output loss over time is dramatically less than with magnetic ballasts
- Fully interchangeable ...Lumatek ballasts can light both HPS and MH bulbs
More lumen output...20%-30% more lumens output...More light equals more people will see the searchlight.
There are no fans to break down or make noise; fan cooled ballast's have a very high failure rate. Lumatek ballasts are very, very reliable. Which is why we offer the excellent warranty.
The ballast can be mounted in areas of high heat. Up to 140° Farenheit.
- Every Lumatek ballast is burned for 12 hours at the factory
- Excellent three year, full exchange warranty
- Lumatek ballasts are 8% brighter than ROM and future ballasts
- No fans to break down after 1 or 2 years
- Safer - The Lumatek ballast is completely sealed from the inside
Ballast comes with 15' Lampcord !
Most companies add $35 for this cordset
This ballast will run a HPS or MH 1000 watt Bulb
When Selector switch is set to 600 it will run a 600 watt MH or HPS bulb
The Dual Voltage Ballast comes with a 120 volt power cord ( regular 3 prong) or special order 240 volt cord.
New Switchable / Dimmable 10000 watt ballast
Will Run 1000 watt bulbs, 750 watt bulbs & 600 watt bulbs
Price: $349.95
326.20
USD
____________________________________________________________________________________________________
The Sun Master bulb has a nice searchlight color, and very pleasant when shined on things.
[FONT=Arial, Helvetica, sans-serif]
[/FONT] Sun Master bulb being made
This combination seems to work well, and will get me through until I get more $$$ to upgrade.
