4&5 IMR26500 M*g by FiveMega
LEDAdd1ct
Well-known member
Hudson Valley
I will take:
#01 Blue 4x26500 $98 (AVAILABLE)
#01 Green 5x26500 $108 (AVAILABLE)
#02 Red 5x26500 $108 (AVAILABLE)
I will also post in master "20% Off Sale" thread! :)
ebuchner
Well-known member
What are the chances that 4x26650 will fit the 5x26500? Simple arithmetic tells me that 4x26650 would be 260mm long, 10 mm longer than 5x26500 mm. Will the tail spring accomodate this extra 10mm with the towerless switch listed in the first post? .
Additionally, what are the technical specs for the "towerless switch?" Is it a stock mag switch with the tower removed or is it a custom high current switch set up?
fivemega
Well-known member
California
Maximum available battery length is about 260mm but unfortunately, most of 26650 cells are longer than 65mm.
Towerless switch is a tower removed M*g stock switch.
fivemega
Well-known member
California
[SIZE=+2]Possible to use 3 cells of 66.7mm long in 4x26500 bodies.
Some 26650 cells are about this length.
Also possible to use 3 cells of 75mm long in 5x26500 bodies with 25mm spacer.
All protected 21700 cells are about this length or shorter.[/SIZE]
