rayearth
I'd like to make a 4 white luxeon headlamp to use in close quarters for spot illumination. Goal is to get about 2-3 hours run time in a entirely headband contained unit. Due to weight considerations, I'll probably go with lithium-ion as they have some of the best energy storage density for the weight. I can get some surplus 7.2v packs cheap and I have the appropriate charger to go with it.
The difficult part of the design is a current limited driver circuit. I think I'll use the Linear Technology LT1308B, unless anyone has a better suggestion. Since the power output is current limited, I would hook up the 4 luxeons in series. I need help for
1) where's the best source to get the parts
2) what values to use as Ned Swiki's page on the Luxeon flashlight mod that uses this chip does not provide much in the way of values
3) is there a way to insert a variable resistor to adjust light output?
