GarageBoy
The Princeton Tec Amps look nice
Help Support Candle Power Flashlight Forum
They do. Unfortunately, they're flashlights, and in that regard, they are wholly unimpressive.The Princeton Tec Amps look nice
They don't have to be impressive if they can be fitted with a high-ouput aftermarket drop-in and high-performance AA cells.They do. Unfortunately, they're flashlights, and in that regard, they are wholly unimpressive.
You realize it's a plastic host and won't be able to dissipate any heat? (It could make a good battery roaster!)They don't have to be impressive if they can be fitted with a high-ouput aftermarket drop-in and high-performance AA cells.
Both beams are ugly to the point of distracting. The beam profile from the 3x 5mm's doesn't vary enough from the primary beam to justify the 5mm array (should have just given the primary LED two levels). And the 5mm beam is the typical, ugly cool temp.Well, the Amps are Rebel 100 and the Amp 5 has a 5mm low mode, so what is there not to like? 70 lumen high is plenty useful and should run for a decent time
Probably me - I've bitched about this light a few times. I never return lights, unless their defective, but I was tempted with the Amp 5.0.I have the 4AAA version with the 4 5mm Nichias, the body itself is pretty nice, but the switch turns on way too easily, can't lockout and you have to hold it for like 3 seconds to turn it off. I believe someone on here had the AMP 5 and they returned it because it's Rebel beam quality wise sucked.
Point well-taken; with a plastic body, you're left with only LED options. But for most of us, that's OK. Even for me, a onetime hotwire. In my recent test, three NiMH AA cells and three NiZn AA cells couldn't power a Lumens Factory high-output lamps to respectable levels. See my results, with beamshots.You realize it's a plastic host and won't be able to dissipate any heat? (It could make a good battery roaster!)
Could you describe what makes the Amp 5's beam "ugly" in more detail? As it is one of the most modern 4AA lights, I am somewhat curious about it.
Also, the UK 4AA eLED Zoom seems to have a modern emitter if its claim of 77 lumens is correct. I have been pretty happy with the build quality of UK lights, seems this one is worth looking into.
How about 2 Quark 2AA tape together.![]()
I just found the UK 4AA eLed zoom comes also in right-angle flavoursand orange too! 🙄
I'd buy a light like the Fenix TK-40 but make it a short stubby 4AA light so that it looks like the Dorcy Solid state that someone posted a pic of on page one of this thread. So keep it thick like the TK-40, but a couple of inches shorter because it's only 4AA.
But instead of the Dorcy, have it be a decent quality light with a metal body for around $100.
How about Fenix making it and calling it the "One Half TK-40"? Use the same head as the TK-40 but eliminate the turbo mode because 4AA batteries can't handle it. Instead just have the low, med, high of the TK-40.
Yeah, I'd buy that.
The primary beam has decent flood, but the hot spot looks like someone put their thumb in it - uneven with lots of artifacts in it. I find it pretty distracting, and I'm not sure how they managed to do that with a Rebel + smooth reflector combo. The 3x 5mm beam is awful - blue, lots of artifacts and reflections from the offset emitter positions, and it's surprisingly concentrated for 5mm's. And, again, unless there's a ridiculous improvement in efficiency from the 5mm array over the primary LED, I don't understand the point of the latter. The profiles of the two beams just aren't significantly different - certainly not enough to justify the added complexity.Could you describe what makes the Amp 5's beam "ugly" in more detail? As it is one of the most modern 4AA lights, I am somewhat curious about it.
:thinking:Point well-taken; with a plastic body, you're left with only LED options.
